I think it was Patrick that found that matched Idss Jfets do not have matched transfer curves.
And Nelson mentioned somewhere that the Pch Jfet should have Idss 80% of Nch, for close transfer curve.
In any case, given that the output devices will have different Vgs causing the input devices operating at different points anyway, and the presence of P3, input devices should be from the same Idss bin but not necessarily matched. I build with matched parts as well as unmatched, and cannot reliably identify any difference.
RS/Darnell do not offer matched devices or matching services.
I think a lot build with mosfet output devices just "off the shelf." I did with no problem. (from Digikey)
Jfets, it is most important to make sure that they are genuine.
Purchase from store, or Spencer on here to be sure. Not E-bay from China.
I have seen "little diode" in the UK mentioned but no one states their quality.
Thanks for the info people ill stay away from China for sure even though sometimes good prices.
I guess I'm safe with diyaudio shipped to UK nice and easy.
I plan to make a really nice sounding amp to beat my Jean Hiraga 20w with smps.
Will be powering this amp with SMPS..
Thanks for the help.
Sent from my SM-G900F using Tapatalk
C
Also what grade Ids would be good for F5
Per Papa's post here, ask for 8+ mA Idss:
http://www.diyaudio.com/forums/pass-labs/121228-f5-power-amplifier-64.html#post1504253
Dennis
Looks like Spencer does have in that ma but how about this ?
Should be fine ?
http://diyaudiostore.com/collections/parts/products/linear-systems-matched-jfet-pairs-grade-b
Should be fine ?
Spencer already increased jfet price, i think that it will be around $19/pair. I have bought from alweit for my previous build, which is $14/pair, hopefully he will not increase it too. I paid same price in this month for 4pairs.
diyAudio - View Profile: alweit
Makes the LSK170 B grade matched pair that I sold seem like peanuts in comparison to those vastly inflated prices.
I still have lots of LSK170 A and C grade matched pairs. Properly matched pairs !
Do you have lsk170 with idss around 15mA
With a tight budget I never hesitate buying components from China using eBay. There are a number of well established vendors with a track record.
Might be of more use to people if you named names.
Blanket "some are ok" does not help purchasers.
- F5 power amplifier
