Vacuum Tube SPICE Models
Thanks jazbo8 and jackinnj. The tetrode pins i use is A S G K, in that order.
I took a second look at the model and changed R1 value and D3 pins. It works and at least screen current at idle is close to the the datasheet now.
.subckt type47 1 2 3 4
+params: KG1=0.00230261 kp1=-6.471 kp2=31.77 kp3=-5.93e-6 kp4=0.1736 kt1=50 kt2=0.08 kc1=6.721e-4 kc2=7.588e-2 kc3=1.708 ks1=3.462e-6 ks2=3.451e-4 ks3=-1.169e-2 kcs=0.09196 ecref=0 esref=250
E1 7 0 Value={V(1,4)}
E2 8 0 Value={V(3,4)}
E3 9 0 Value={V(2,4)}
RE1 7 0 1e12
G1 1 4 VALUE={(KG1*V(7)+((kp1/(kp2+v(7))+(kp3*v(7))+kp4)-KG1*V(7))/(1+EXP((KT1-V(7))*KT2)))*((kc1*V(8)**2)+kc2*v(8)+kc3)*((ks1*V(9 )**2)+ks2*v(9)+ks3)*(1/(1-kcs*(V(8)-ecref)*(1-V(9)/esref)))}
RCP 1 4 1e12
C1 2 3 2.4e-12
C2 1 2 3.9e-12
C3 1 3 0.7e-12
R1 2 5 39000
D3 5 4 dx
.model dx d(is=1e-9 rs=1 cjo=10e-12)
.ends
@ballpencil, I've tinkered with your sim in LTspice. I've edited your 47 model as there were a few inconsistencies. I've simplified the diode model from the control grid to the cathode. Also in the sim I've added a reversed biased diode across the current source to aid in convergence. Below I've attached the edited model, a LTspice file and two screen shots. Be aware that I'm not firing on all cylinders today, so I might have made a goof or two. :D
Code:
.subckt type47 1 2 3 4 ; A S G K
RE1 7 0 1e12
RCP 1 4 1e12
C1  3 4 2.4e-12
C2  1 4 3.9e-12
C3  1 3 0.7e-12
d3  3 4 dx1
.model dx1 d(is=1n rs=2k cjo=0.1p N=1.5 tt=1n)
.ends
  • 47 Plate to Grid Feedback rev02.asc
Hello all!
I'm newbie and maybe that question was already asked, but is there model of vacuum diode? Not triode/pentode, but simple vacuum diode?
I tried make it by myself, using Stefano Perugini's diode definition, but failed (had "The instance has more connections than the definition" error when redrawing triode to diode and trying to use in in the circuit):
* Diode definition by Stefano Perugini
.SUBCKT Diode P C
E1 1 0 VALUE = {KA + KB * V(P,C)}
E2 2 0 VALUE = {V(P,C) + EPS}
G1 P C VALUE = {V(1) * (PWR(V(2), EX) + PWRS(V(2), EX))/2}
C1 P C {CCP}
.ENDS
Thanks for your help!
I am in need of accurate LTspice models for the following Nuvistors:
7895 Triode and 7587 Tetrode. Both are used in the Ampex MR-70 electronics that I am restoring/hot-rodding.
Although I am a serious user of LTspice, I do not have the math chops and model understanding to make my own models without some initial hand-holding. I am aware that there are Koren style models that supposedly work OK with triodes but are not accurate for tetrodes. I understand that there are some other model families that are supposedly better, but I am way down on the learning curve to even be able to determine what model is working correctly or not.
Data sheets for these Nuvistors are available complete with curves and numeric data. I just don't know personally how to translate the data into a model so I can try out the circuit topologies that I want to examine.
Thank you in advance for any help you can give me.
Steve Hogan
714 871-6636
714 904-6636 (cell)
Ex-Moderator
Joined 2011
7859 SPICE Model
Code:
* Generic triode model: 7895_AN
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Sun Apr 17 16:20:27 2016
*               Anode
*               | Grid
*               | | Cathode
.SUBCKT 7895_AN A G K
BGG   GG   0 V=V(G,K)+0.3310575
BM1   M1   0 V=(0.021476228*(URAMP(V(A,K))+1e-10))**-2.5656488
BM2   M2   0 V=(0.3689448*(URAMP(V(GG)+URAMP(V(A,K))/29.383894)+1e-10))**4.0656488
BP    P    0 V=0.0099212093*(URAMP(V(GG)+URAMP(V(A,K))/79.643063)+1e-10)**1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.039321732*V(M1)*V(M2)
BIG   IG   0 V=0.0049606047*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK  A    K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.0051480463*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK  G    K I=V(IG)
* CAPS
CGA   G    A 0.9p
CGK   G    K 4.2p
CAK   A    K 1.7p
.ENDS
Ex-Moderator
Joined 2011
7587 Tetrode Model
Code:
* Generic pentode model: 7587_AN
* Version 3.10, Generated on Sun Apr 17 19:35:04 2016
*               Anode
*               | Screen Grid
*               | |  Control Grid
*               | |  |  Cathode
.SUBCKT 7587_AN A G2 G1 K
BGG   GG   0 V=V(G1,K)+-0.93083831
BM1   M1   0 V=(0.056230366*(URAMP(V(G2,K))+1e-10))**-1.8620379
BM2   M2   0 V=(0.44615798*(URAMP(V(GG)+URAMP(V(G2,K))/9.8495184)))**3.3620379
BP    P    0 V=0.017475627*(URAMP(V(GG)+URAMP(V(G2,K))/22.076302))**1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.026138039*V(M1)*V(M2)
BIG   IG   0 V=0.0087378137*URAMP(V(G1,K))**1.5*(URAMP(V(G1,K))/(URAMP(V(A,K))+URAMP(V(G1,K)))*1.2+0.4)
BIK2  IK2  0 V=V(IK,IG)*(1-0.4*(EXP(-URAMP(V(A,K))/URAMP(V(G2,K))*15)-EXP(-15)))
BIG2T IG2T 0 V=V(IK2)*(0.71533934*(1-URAMP(V(A,K))/(URAMP(V(A,K))+10))**1.5+0.28466066)
BIK3  IK3  0 V=V(IK2)*(URAMP(V(A,K))+2650)/(URAMP(V(G2,K))+2650)
BIK4  IK4  0 V=V(IK3)-URAMP(V(IK3)-(0.0099385622*(URAMP(V(A,K))+URAMP(URAMP(V(G2,K))-URAMP(V(A,K))))**1.5))
BIP   IP   0 V=URAMP(V(IK4,IG2T)-URAMP(V(IK4,IG2T)-(0.0099385622*URAMP(V(A,K))**1.5)))
BIAK  A    K I=V(IP)+1e-10*V(A,K)
BIG2  G2   K I=URAMP(V(IK4,IP))
BIGK  G1   K I=V(IG)
* CAPS
CGA   G1  A  0.015p
CGK   G1  K  4.2p
C12   G1  G2 2.8p
CAK   A   K  1.4p
.ENDS
Ex-Moderator
Joined 2011
1P24B Pentode Model
Code:
* Generic pentode model: 1P24B_AN
* Version 3.10, Generated on Mon Apr 18 09:52:29 2016
*                Anode
*                | Screen Grid
*                | |  Control Grid
*                | |  |  Cathode
.SUBCKT 1P24B_AN A G2 G1 K
BGG   GG   0 V=V(G1,K)+0.78441583
BM1   M1   0 V=(0.050203142*(URAMP(V(G2,K))+1e-10))**-0.42612758
BM2   M2   0 V=(0.77876462*(URAMP(V(GG)+URAMP(V(G2,K))/4.4068036)))**1.9261276
BP    P    0 V=0.00078336376*(URAMP(V(GG)+URAMP(V(G2,K))/5.6587106))**1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0004582081*V(M1)*V(M2)
BIG   IG   0 V=0.00039168188*URAMP(V(G1,K))**1.5*(URAMP(V(G1,K))/(URAMP(V(A,K))+URAMP(V(G1,K)))*1.2+0.4)
BIG2T IG2T 0 V=V(IK2)*(0.94497705*(1-URAMP(V(A,K))/(URAMP(V(A,K))+10))**1.5+0.05502295)
BIK3  IK3  0 V=V(IK2)*(URAMP(V(A,K))+10000)/(URAMP(V(G2,K))+10000)
BIK4  IK4  0 V=V(IK3)-URAMP(V(IK3)-(0.00060825471*(URAMP(V(A,K))+URAMP(URAMP(V(G2,K))-URAMP(V(A,K))))**1.5))
BIP   IP   0 V=URAMP(V(IK4,IG2T)-URAMP(V(IK4,IG2T)-(0.00060825471*URAMP(V(A,K))**1.5)))
BIGK  G1   K I=V(IG)
* CAPS
CGA   G1  A  0.008p
CGK   G1  K  4.5p
C12   G1  G2 3p
CAK   A   K  4p
.ENDS
