TPA3116 Upgrades
TPA3116 Dual Board Questions
Hi all,
I've been lurking here for a few weeks. I've finally got a few questions that I'm not too sure about. I purchased this board: 2*100W TPA3116 D2 Dual Channel Digital Audio Amplifier Board 12V-24V for Arduino
Regarding the upgrades; can I use the components suggested here or are there other requirements since this is a dual chip board?
TPA3116D2 Boards - diyAudio
Which swap would give me the best bang for the buck?
Also, does anyone have a schematic for this dual chip board?
Thanks!
There's no difference between components for single/dual chip. I would suggest starting with bootstrap snubber mod if this part is not already present on your board. You can also swap output filter capacitors and inductors. Can you make a hi-res photo of the board without heatsinks?
Is rather not remove the heatsink. Here is a pic.
Hi all,
Thanks!
I have purchased 2 of these boards off EBAY, and they both sound pretty darn good right out of the box with a 24VDC 5 AMP SMAKIN power supply brick available from AMAZON. Why fix something that sounds good already? Just build a box with a power supply adapter plug, RCA inputs, and some banana plugs and enjoy. If one board craps out it's only $10.99 for a replacement.:)
Mac:D
Mac:D
I definitely agree. I guess I just feel like tinkering with it.
If anyone is interested, here are some upgrades to the dual chip TPA3116. The board sounded decent but a bit harsh on the highs. Two of stock power caps began swelling just after a two days of listening.
The mods are:
Panasonic 25SEPF330M power caps
TDK FK20X7R2E224K bootstrap caps
Bourns 2100HT-220-V-RC inductors (for 8-ohm)
Wima MKS4D036802E00KSSD output caps
The mods made the amp sound very good and much smoother. After doing a very ghetto snubber mod, the harshness is gone. :p
Oscons are more easily damaged than wet electrolytics, so I would check if there is an external (to ampboard) reason the chinese electrolytics bulged, the dc converter??
"Bootstrap"snubbers are for each inductor, you have 4 inductors. If wires are long, they probably have no job.
Thanks for the reply irribeo.
I will look into what caused the swelling on the electrolytics. I thought it was an side effect to cheap components but will test how good the DC power supply is under load.
In the quick haste of doing this mod, I failed to realize that the snubbers are per inductor basis. When ordering the components, I just came to the quick conclusion that 2 chips = 8 snubbers. I was afraid that the long wire extentions will diminish the effect of the snubbers but it was difficult to implement without shorts due to the board layout. I did hear a sound difference after just doing the snubbers but it might just be a placebo now :D. Perhaps I can properly do the mod since I can remove 4 of the snubbers.
Thanks again for pointing me to the right direction!
