Vacuum Tube SPICE Models
Hello jazbo8, I wonder do you have time to create a LTspice model for 6KY8a. I have the triode-connected curve for 6KY8a beam power section as shown below.
Your 6DS5 model worked great, I used it simulating a SE amp (using 6j6 as Voltage amp). I am going to build it as part of my Summer project. Thank you again!
Ex-Moderator
Joined 2011
6KY8A Pentode Section SPICE Model
Please be aware that this model was built using the triode-connected data that you provided, and it unfortunately did not match the pentode characteristic shown in the RCA datasheet, so bear that in mind when you use it.
Code:
* Generic pentode model: 6KY8_P_AN
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Sat Jun 20 06:53:43 2015
*                 Plate
*                 | Screen Grid
*                 | |  Control Grid
*                 | |  |  Cathode
.SUBCKT 6KY8_P_AN A G2 G1 K
BGG   GG   0 V=V(G1,K)+1
BM1   M1   0 V=(0.095313333*(URAMP(V(G2,K))+1e-10))**-1.0989454
BM2   M2   0 V=(0.57715719*(URAMP(V(GG)+URAMP(V(G2,K))/4.4363448)))**2.5989454
BP    P    0 V=0.0031004553*(URAMP(V(GG)+URAMP(V(G2,K))/7.6865452))**1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0022026287*V(M1)*V(M2)
BIG   IG   0 V=0.0015502276*URAMP(V(G1,K))**1.5*(URAMP(V(G1,K))/(URAMP(V(A,K))+URAMP(V(G1,K)))*1.2+0.4)
BIK2  IK2  0 V=V(IK,IG)*(1-0.4*(EXP(-URAMP(V(A,K))/URAMP(V(G2,K))*15)-EXP(-15)))
BIG2T IG2T 0 V=V(IK2)*(0.85149976*(1-URAMP(V(A,K))/(URAMP(V(A,K))+10))**1.5+0.14850024)
BIK3  IK3  0 V=V(IK2)*(URAMP(V(A,K))+1500)/(URAMP(V(G2,K))+1500)
BIK4  IK4  0 V=V(IK3)-URAMP(V(IK3)-(0.0021745412*(URAMP(V(A,K))+URAMP(URAMP(V(G2,K))-URAMP(V(A,K))))**1.5))
BIP   IP   0 V=URAMP(V(IK4,IG2T)-URAMP(V(IK4,IG2T)-(0.0021745412*URAMP(V(A,K))**1.5)))
BIAK  A    K I=V(IP)+1e-10*V(A,K)
BIG2  G2   K I=URAMP(V(IK4,IP))
BIGK  G1   K I=V(IG)
* CAPS
CGA   G1  A  0.048p
CGK   G1  K  1.6p
C12   G1  G2 1p
CAK   A   K  0.3p
.ENDS
Hi jazbo8, thank you!
I have three sets of the triode-connected data here, would you please to check out which one can get better match with the RCA datasheet?
Thanks again!
Ex-Moderator
Joined 2011
Unfortunately, none of them is close to the datasheet, the mis-matches are the greatest at higher bias voltages (Eg1 > -10V), the datasheet shows lower current than the samples. In any case, the tubes can work over a wide operating range, so the model that I provided should suffice for now until a better sample comes along.
Hello jazbo8, thank your so much for your helps!
I got the curves from this website "http://homepage2.nifty.com/Kame/6KY8Asyu.htm",
I simulated your model using "DC sweep" in LTspice, the results matched well with their Ip vs Vp curves (@Vsc=120V). Please see the attachments.
I also attached the curve of 6ky8 triode section, is the triode section the same as 12AT7 or similar?
Thanks again!
Ex-Moderator
Joined 2011
the results matched well with their Ip vs Vp curves (@Vsc=120V). Please see the attachments. I also attached the curve of 6ky8 triode section, is the triode section the same as 12AT7 or similar?
Good to see that the model matches up with the pentode characteristic on the Japanese site, since that was the sample used to build it in the first place (or close to it). Also the triode section appears to be very different from the 12AT7, not sure of what the closest equivalent might be...
6KY8A triode section LTspice model
6KY8A triode section model for LTspice.
Code:
* 6KY8AT LTSpice model
* Rydel model (5 parameters): mean fit error 0.150746mA
* Traced by Wayne Clay on 6/22/2015 using Engauge Digitizer and
* Curve Captor v0.9.1 from RCA datasheet.
.subckt 6KY8AT  P G K
    Bp  P K  I=
+ ((0.00144469087m)+(-0.0001050179892m)*V(G,K))*uramp((71.84993107)*
+ V(G,K)+V(P,K)+(62.44961062))**1.5 * V(P,K)/(V(P,K)+(3.613380107))
  Cgk G K 15.2p ; 0.2p added (15p, K+H)
  Cpk P K 7.2p ; 0.2p added (7.0p, K+H)
  Cgp G P 1.14p ; 0.7p added (0.44p)
  Rpk P K 1G ; to avoid floating nodes
  d3  G K dx1
.model dx1 d(is=1n rs=2k cjo=1pf N=1.5 tt=1n)
.ends 6KY8AT
