Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KHz
Yeah, I see that in Soren's original file, there are less than 400 coefficients for 44.1k. I think 1015 is the total for all the frequencies? Please tell me if I am wrong.
The original 44.1kHz filter has 383 taps. This number can be increased to 1015 taps at 44.1kHz and provide performance benefits (greater attenuation, ripple reduction,...).
(The original filter file contains over 1200 taps for the various fs configurations. 1276 taps)
Søren, as a content user of a Soekris net-board and interested reader of this thread (as well as one or to other that may turn into a Best-buy DIY-Dac) I feel I have to respond to your answer to rickmcinnis.
For those of us who are battery enthusiasts -
Is it possible to be shown where the +- 4 volts regs are located on the board?
They are very well hidden!
THANKS!
Sorry, this is still a commercial product, there are limits to how deep modifications I can or will support....
I can only recommend to supply any power on J1, and J3 is NOT for supplying power.
If you insist to improve the onboard power supply, try replacing the 6 electrolytic capacitors with aluminum polymer types, 1000u 16V exist in same 10mm smd footprint and t.ex. digikey stock them at $2.20 each. Should be easy to replace.
I don't have time to listen that much, but if everybody listen some and we then can agree on a set of filters, then the R-2R DAC should reach its maximum potential....
Søren, not to be offensive but you started posting about your dac in the Digital Line Level-forum, asking for inputs to your construction.
It seems there´s still some work to be done regarding filters, which you kind of ask the DIY-community to help you with (= maturing your commercial product for the benefit of all, non-DIY´ers (and yourself) included).
Revealing the location of the regs asked for doesn´t mean supporting the mod; I´ll image you´ll advise against it. I´m also sure rickmcinnis as well as others who intend modification of the board itself are aware of the risks involved..
With the deepest respect for yours and forum-members´ combined efforts in this product
Regards, Finn (satisfied user of modified to - and improved - battery-power dac)
Maybe getting a bit closer connecting to the umanager.
New usb-serial interface. Short cable.
Stops here. Unable to type anything. But there is a connection.
Powercycle and the same happens.
The dam1021 FIR1 is operating at 352.8K/384K and each filter can have up to:
1016 tabs at 44.1K/48K input sample rate
508 tabs at 88.2K/96K input sample rate
252 tabs at 176.4K/192K input sample rate
124 tabs at 352.8K/384K input sample rate, but normally bypassed
FIR2 is operating at 2.822M/3.072M and can have up to 120 tabs, with input sample rates 352.8K/383K.
All upsampling is done by zero insertion, therefore gain need to be set to match oversampling rate.
There can be multiple of each filters in the 1021filt.txt filter file, but minimum one need to be there for each input sample rate. Currently just the first one for a given sample rate is used, in later firmware releases you will be able to choose between different filters.
Again, you need to know what you're doing if you want to do your own filters, it's not that simple and there aren't much error checking in the tools....
TNT
Joined 2003
After having listened to 44,1 via the filter made by pos, I'm confident that this can turn out really good. This filter make the DAM sound quite laidback, almost soft. Havent got my speakers back so I enjoy this throgh a pair of Philips SRC HP980 via the active output of the DAM. I will try to make one myself starting form the pos filter design and see where it may end up. I hope I can not destroy the DAM in any way by loading strange filter. Ears migth have to be protected.
A Users Club with a lot of filters too choose :)
Dear finnogangela,
Thanks for your note.
In deference to Soekris I would like to say more about this.
I was worried, in this litigious age, that Soekris had legitimate fears that anything he says could be construed as an "OK". I wrote him a PM and he kindly responded.
His main comment was that my request for information might be a little too close to his IP, he calls it his "secret sauce", and I surmise, since the only thing that could explain where they are, is that they are intertwined with the FIR chips and I am guessing there are twenty of these supplies (ten of each polarity? I do not know) which would make it quite impossible for me to replace them with batteries.
So after all is said and done I agree with Soekris's position even though I wish he would have just made it plain but ... We can think of this as a community project and that is an aspect but it is still Soekris's idea and implementation and we have no choice but to respect how much he is willing to reveal.
Nonetheless, thanks for sharing my frustration but I have to say on this Soekris is right, just a little cagey!
Thanks and take care,
Disabled Account
Joined 2005
Fred: 1015 taps is the maximum numbers of taps that the DAM can currently use for FIR1. For a FIR, the more taps, the better to manipulate (filter) the signal.
The reason for using 1015 rather than 1016 is that rePhase has a bug when using an even number of taps.
The changes to the txt file are straight forward to make. Export from rePhase as 32bit mono float, and paste to replace the existing FIR coefficients immediately after the relevant header.
You would then need to alter the first line of the section header to reflect the number of taps filter you have inserted.
Code:
dam1021,44100,8,1,[b]1015[/b],8
Input FIR, 44.1 Khz Samplerate, 0-19 Khz +- 0.01 db, 24 Khz -110db
0.0000000000000000000002205955035956718
-0.000000000003583024540513104
-0.000000000009705691392355318
0.00000000002827615964380067
0.000000000005400389449492969
-0.0000000000000000000001631140623808514
dam1021,48000,8,1,319,8
Input FIR, 48 Khz Samplerate 0-21 Khz +- 0.01 db, 28 Khz -110db
No access to the uManger
For ZTerm:
Go to Dial > Directory
Click "New"
Create a config with name "Soekris R2R", Data Rate "115200", Data Bits "8", Parity "None", Stop Bits "1" Flow control options all deselected. Select Local Echo if you want to see what you've typed.
Click "OK"
Got to File > Transfer Convert and select "Binary Data" - the default "Smart MacBinary" corrupts transfers.
To connect select "Soekris R2R" from the Dial menu. You should see "Direct Connect Soekris R2R" in the terminal window.
Also make sure you connect TX on the adapter to RX on the board, and RX on the adapter to TX on the board. You need to have the cable wired as a cross-over configuration for to work.
cheers
Paul
Hi I am on a Mac also and followed your advice, but I just do not see the uManager.
When I open Z term I see: ATE1 V1) so it seems to see the Dam1021, but when I type +++ nothing happens, what else can I try?
Thanks for help.
Tobias
