100W Ultimate Fidelity Amplifier
Apex A9 irfp240/irfp9240
credits PCB Sonal kunal
Mods Thiago
not tested
By the way, last weeks I have built the A9, A14, A17 and A33.
My Hitlist is:
- A14
- A9
- A17
- A33
But that's just my subjective opinion and only based on listening music. Now a lot of new amplifiers were built. I'm curious how you see it. Any experiences? What is your rating?
regards Olaf
You must ask alexmm or olafk, I never made A33,
ok I will ask them I'm really interesting on the A33 circuit :) thanks I have the layout almost done from mister Alex MM PDF files I like it so much that I have to have it, really nice placement thanks Alex I'm gonna order a few for me yes !
Juan
You must use multi turn potentiometer and for correct bias adjust 680 ohm resistor will be change to 1 Kohm value . Today I have tested A33 amplifier with +/-50V voltage rails and playing nice .Only first two MJE340 and MJE350 are warm ,so I attached a small heat sink .:)
Regards,Alex
Instead of 680ohm+200ohm multiturn , I use 330 ohm and 1k ohm multiturn.
I had many of 1k multiturn ...
Thanks , Laur
Hi Alex,
Please explain further. What value do you use for P1 and what value do you use for P2? May I assume the 680R you refer to is the one in the VBE multiplier?
Thanks, Terry
Hi Terry,
I used 200 ohm MT and 1K ohm resistor for bias .... and 4K7 MT for offset adjust.
Right ,680 ohm resistor it's from the VBE multiplier
Regards,Alex
