Shigaclone MKII Black - The builders Thread
Bad tracking and poor playback.
Hi Tibi,
Trust you are well.
I have done as you said and cleaned the circuit board with iso prop. It was filthy, my bad :headbash: . Now it's all clean and shiny.
It now works like a dream and plays my oldest CDs which are scratched very badly. My Brother's in Arms CD plays again. I did find another error with a capacitor. I put a 6V 470uF instead of 16V 470uF in C13. I must have misread the parts list when I ordered my parts from Mouser.
I've also installed the hot rodded drive you supplied. Since I've never listened to a bog standard one I can't comment on what improvement this offers. All I will say is it sounds very good indeed. My own attempt worked but was a right mess. I've since bought some smaller tips for my iron.
Thanks again for all your assistance.
Cheers, Aleks
Hi Tibi,
Need abit of help here. I hook up everything except:
1) digital out cable
2) remote control battery
Issue:
1) the LED on the Psu board is not working but measure 8v.
2) no reading from the mechanism. The screen shows 00. I pressed the Door button the disc start spinning and shows ' -- ' then back to '00' again. I was using proper bought cd. When the cd spins, I can hear and see the lens move in mm few times then stop. Anything I missed out?
Thanks!
Hi Tibi,
Issue:
Thanks!
Laser protection solder blob ?
Tibi
