ExtremA, class-A strikes back?
Joined 2005
I couldn't resist whipping up Pavel's idea in the simulator, made it into a full bridge for better efficiency and set the output for 80W/8R. The numbers I got aren't in the least bit disappointing, here's the THD20K at 80W/8R:
Fourier components of I(r38)
DC component:1.88071e-006
Harmonic Frequency Fourier Normalized Phase Normalized
Number [Hz] Component Component [degree] Phase [deg]
1 2.000e+04 3.171e+00 1.000e+00 -0.28° 0.00°
2 4.000e+04 3.375e-06 1.064e-06 -55.67° -55.39°
3 6.000e+04 5.025e-06 1.585e-06 -118.35° -118.07°
4 8.000e+04 2.325e-06 7.333e-07 157.09° 157.37°
5 1.000e+05 1.683e-06 5.308e-07 77.54° 77.82°
6 1.200e+05 9.958e-07 3.141e-07 0.57° 0.85°
7 1.400e+05 4.393e-07 1.386e-07 -107.32° -107.04°
8 1.600e+05 4.818e-07 1.520e-07 101.26° 101.54°
9 1.800e+05 8.989e-07 2.835e-07 7.13° 7.41°
Total Harmonic Distortion: 0.000216%(0.008551%)
Try to run asc file
http://www.diyaudio.com/forums/solid-state/96853-extrema-class-strikes-back-30.html#post4120514
Fourier components of I(r40)
DC component:0.000407211
1 1.000e+04 2.669e+00 1.000e+00 178.12° 0.00°
2 2.000e+04 5.812e-08 2.178e-08 3.00° -175.12°
3 3.000e+04 5.652e-06 2.118e-06 -124.58° -302.70°
4 4.000e+04 3.135e-08 1.174e-08 -0.20° -178.32°
5 5.000e+04 3.423e-07 1.282e-07 67.10° -111.03°
6 6.000e+04 2.038e-08 7.636e-09 0.03° -178.09°
7 7.000e+04 2.216e-08 8.303e-09 -60.47° -238.59°
8 8.000e+04 1.510e-08 5.659e-09 -0.11° -178.23°
9 9.000e+04 1.385e-08 5.188e-09 5.15° -172.97°
Total Harmonic Distortion: 0.000212%
Joined 2005
Try to run asc file
Are you referring to the discrete design, or the opamp design? I'm assuming the former? In that case, .four 20k I(R40) is what you'd like to use.
So try it, simply edit 10kHz to 20kHz..
DC component:0.000265904
1 2.000e+04 3.465e+00 1.000e+00 176.23° 0.00°
2 4.000e+04 8.835e-09 2.550e-09 28.75° -147.48°
3 6.000e+04 4.338e-06 1.252e-06 -138.55° -314.78°
4 8.000e+04 1.114e-08 3.216e-09 -8.34° -184.57°
5 1.000e+05 3.114e-06 8.989e-07 63.60° -112.63°
6 1.200e+05 5.183e-09 1.496e-09 -7.20° -183.43°
7 1.400e+05 3.595e-07 1.037e-07 -119.38° -295.61°
8 1.600e+05 3.816e-09 1.101e-09 -12.84° -189.07°
9 1.800e+05 4.946e-08 1.427e-08 61.28° -114.96°
Total Harmonic Distortion: 0.000154%
Disabled Account
Joined 2012
:cool::) Nice idea.
Kinda reminds me of driving a OPS bias pair with ref to the output. Conceptually, wasnt that done in a former life with a diode-resistor from output to bias (spreader)? (NPass). But this is a nice balanced circuit refinement.... like a comparitor, too.
Opamp input now then one of the many good discrete front end, later?
THx-RNMarsh
No load on the opamp is great as that was the last area of concern (OPS loading) for using opamps. How much current does the sim say the opamp must supply (max) when the amp goes out of class A?
THx-RNMarsh
Not nice, then. Starts quite mild, as attached, but continues to milliamps and tens of milliamps.
The image is for stepped load 8, 6, 4 ohms. You can see input current and ouput current through one output device.
added an image for 2 ohm load
