Post your Solid State pics here
And finally...
I will have to presume either the diyer has good access to CNC or good budget to a CNC:D:D
I do have a background in aerospace ...and an interest in machining. I made all the drawings and built almost everything myself. Bought the raw aluminum and copper at a metal supplier. But I had to have the faceplate and all the numerous holes on the top plate done at a machine shop (could have done the holes myself but it would have taken forever...wouldn't cut it with WAF factor !!!).
Of course had the engraving done also. About 300$ for both machining and engraving. Not cheap but still accessible.
Scorpion
Scorpion
Beautiful workmanship!
Where did you get the machining done? I'm looking for CNC shop
Do
Hi sure, I have thread here http://www.diyaudio.com/forums/solid-state/225292-diy-200-watt-solid-state-monoblock-power-amplifier.html
I will post more hifi porn eventually. Have to sort out pictures first, I have taken hundreds of them
Thanks for the link Teti. I saw lots of pics of the amps' inside. Impressive, really. Again, outstanding work. If your amps sound half as good as they look, they should be in a different league.
You have me drooling. Congrats again.
Scorpion
