Hi all
First One exhibiton-show chassis in B&W design just came into assembly line.
Me happy
"My god. They're full of stars."
That is a very attractive chassis.
Yes of course, but thin wire to DC sense is sufficient, few mA runs only to opto LED.
Ok, I'll take two sets then
Do
Do
Are you interested in FO v1.3 too?
See you there.
You're all welcome to room 109.
What kind of question is that, of course I'm interested in FO V1.3!
But you said it was commercial and not yet available for DIY? I do have two V1.2 modules.
Ciao!
Do
Hello all, total newbie so I'm a bit confused. I want to put together 3 of these amps for my front left/right and center speakers. They are just simple two-way 1"/6" and I live in an apartment so I won't be playing it very loud and there is not a lot of low frequency being generated. Needless to say, I won't be pushing these amps too hard. For the power supply, I really wanted to drive the three amps off a single PS, probably a Hypex. I read through nearly this whole thread, and think I understand the benefits/negatives of the single PS, but I cannot figure out the sizing if I go this route. Looking for recommendations, would you go with the 400, 1200, or 3k version of the A400 unit? Also, would you use the soft start board?
Thank you so much
Thank you so much
Sonicman member stonehome did go the single PSU route see post 1303/1307, you could try PM him.
Member pinnocchio revealed post 1412 will test multiple brand and type of PSU link here Amplificateur FO (First One) avec alimentation AudioPower SMPS.
Good investigation/planning.
Thank you so much
You can go with 1 single hypex SMPS1200A400, soft start is not needed with this SMPS.
Of course separate PS (3x SMPS1200A400) is better
Sonicman, I have planned to power four modules from one smps1200 for my build. So far in the builds shown the most modules powered from a single power supply is two.
The only issue will be whether the SMPS will start up with more modules attached due to the fairly large bias current (280mA per module). Some other SMPS's have had trouble starting with these bias currents.
I will hopefully test this out in the next couple of weeks and can report success or failure with four modules. All of the Hypex SMPS's have a built in soft start facility so there is no need for a separate board.
My SMPS can face 10A at start up without problems,
http://i39.servimg.com/u/f39/19/01/03/77/2014-012.jpg
Good luck
Andrej,
Any news or feedback from the show?
Today Multimedia Show started in Ljubljana, report, pics and links follow soon.
Thank you all for the feedback on the multi-channel solution with single PS. I'm not qualified to test the electronics (my background is acoustics), but I'm happy to buy and try and tell you if it blows up or not ;-)
I ordered the 3k version just to have the headroom.
Good luck
LC
I can have a board with only one pair of mosfet ! ....... not sure but I believe that there are 3 pair on it
I need only 50 watts / 8 ohm
Thank
See post 20, single pair of dual die Mosfets
http://www.diyaudio.com/forums/vend...ne-mosfet-amplifier-module-2.html#post3772493
Do
Merci Do ( deux paires ) , je l'avais lu , mais après plusieurs autres pages ça m'a sortie de l'esprit .... quand même 100 watts par paire , il doit être ( le bias ) très près du class B ........... ça avance pour ton évaluation ?
Babylon translation ;
Thank You Do , i had read , but after several other pages it's told me out of my head .... with even 100 watts per pair , it must be ( the bias ) very near the class B ........... your evaluation .... soon ?
LC
It is feasible to have a module with bias in Class A?
Thank
LC
Thank
4mc2, do you feel ~150mA/pair "very near the class B" (if i'm not wrong about the FO)?with even 100 watts per pair , it must be ( the bias ) very near the class B ........... your evaluation .... soon ?
With decent efficient enclosures, you'll be in Class A for most of the musical program at good listening levels. Who want to spend more watts for transients so fast that you'll never notice any distortion witch will be, anyway, under your listening thereshold ?
This said, nothing (but cooler size) impeach-you to increase the quiescent current if you like. It will not even change the quiescent of the VAS.
You can have a look to the VSSA (80W/8Ohms) too.
Thanks for the order, First One modules v1.3 prepared and send in a few days.
Andrej,
Took myself one week vacation, brains in off position.
- Vendor's Bazaar
- First One - mosFET amplifier module
