Tas5630+smps+aluminum case finished!new year coming!
I have sent lots of emails but you only reply on a public forum, proving you are scammers!
We check the order again just now, ther are no your reply indeed.only one reply we write just now.
if you met overheat problems, maybe the TAS5630b chip fault.
you ordered one g300v33 amp is the old version, we have update to new version, improve it's EMI performance, it have better over current protection function now.
it have two version:
Stereo module:
Aliexpress.com : Buy 400W 2CHANNEL TAS5630B High Stability CLASS D Amp Interagrated High Efficiency SMPS BLACK BOX design from Reliable stabil suppliers on SINEWAVE SAMPLE STORE
mono module:
Aliexpress.com : Buy G300V33PBT TAS5630B PBTL High Stability CLASS D Amp Interagrated High Efficiency SMPS BLACK BOX design from Reliable stabilizer parts suppliers on SINEWAVE SAMPLE STORE
we think it is the best solution of TAS5630 we made now, because we offical use this chip from 2007-2014, from 100pcs/year to 5kpcs/years we get rich experiences with this chip now, even we know our TAS5630 amp have shortage still, because TI company team improve these series chip along.
we will find more way to make it perfect.
I am not going to return something you know is faulty by design, until I receive a product that works! until then my opinion of your company remains the same you are scammers!
You assembled a whole heap of amps that didn't really work, and you knew that and you still sold them to get back build costs!
Its easy to take my money, its harder to be a trustworthy reliable seller!!
if only overheating problems, please add one fan cool system on you applying, you know it’s power higher.but heatsink small .
it is joke to believe your words,all your words you said show you want to smear others with 150usd ,cost so cheaper.we think without engineers like to do it, only take money rumor,
You took my money and sold me junk.... what else is there to believe, you didn't actually test your products? or your engineers are idiots?
All the batch products pass our strict testing, Proamp products pass AP tester measurement and 6-24hours full loader testing.
About you ordered one sample, you can add one dc brushless fan in your case ,you can find most of the simliar products online do it like this, we only provide module, not completed amp with case, your case should have fan cooling space.
It is simple technology, if you have not fan and you canot order it in your local, you should ask one from us, we will help you get one.
we test g300v33 without any SMPS chip heatsink at full loader, only add one fan cool side, works well,you can find it in the no.1 photo
some tester photos here, please check.
on line test , we use special fixture to test output shorted protection over loader protection easily. it is common technolgy,where is the junk?
500W rms 100V Output Transformerless Amplifeir Testing
Our new 1U height 500W rms 100V Output Transformerless Amplifeir Testing now, take some prototype machine photos from our lab just now.
Dimensions:
(Body) 348mm(Length)X148mm(Width)X45mm(height)
(Rear Panel) 174mm(Length)X45mm(Height)X2mm(Thickness)
Features:
1.500W mono PA amp, RMS power @ 100V transformerless output
2.220V or 110V ac supply selected
3.1u height
4.Self test function/auto self test function/report amp status to RS485 .
5.RS485 remote standby and mute function.
6.Perfect protection function, High stablity
These guys are scammers, I bought a pre assembled amp, and now Im being told to install a fan that they didnt install, there is now power for the fan on the PCB wtf this thing is just made wrong!
Pick up your game!
There is no room in the case, that they supplied for the FAN! its not ment to have one!
WTF
If you tested it for 6hr+ why does it need a Fan if you did the testing without a fan?
This makes no sense its just a scam!
Pick up your game!
WTF
First you should know some technology, if you don't know only a little audio amp technology, let's tell you below:
Only two step necessary.
No.1 add one 12v dc brushless fan red wire to' +14v' connector pin.
No.2 add this fan black wire to 'GND' connector pin
No.3 if you fan not work when power on, please check this fan good or fault.
Second we are all diyaudio member,most of the members are engineers, it is quality people here, none named guys.
if you have any other questions, please post here , we will arrange our team to tell you how
Third add addtional technology here:
if you use 12v dc burshless fan with this board, and find noise bigger, please check the fan defalut current and series one 2W resisters in the middle of red wire, resister value from 1R-10R, you can test it and calculate it according to the ohm's law. usually you can find the default current in the fan mark.
If you use 24v dc brushless fan, you can add positive to '+14' and negative to' -14', 2w resister necessary at this conditions, of course u can calculte it with above conditions.
if you can't calculate this with your conditions, please let us know, we will simulate here and take some photos for you.
user manual file size too bigger to upload here. you should find your answer in there
We discuss your met issue with our engineers and sales just now, we found we made mistake , you ordered completed amplifier ,not amp module.
Few questions, please help us reply it, we will process it quickly , you know today is work time. all of us are in office now.
1. You ordered amp is completed amp with aluminum case, not module only
2. It is custom-made amp with aluminum case base on the G300V33BTL module, not original G300V33 module. We only make one simple for you so far. this aluminum case smaller than G300 amp.
3. You mentioned overheating temperature how many?
This amp play sound about 8hours and full loader burning-in 24hours(with fan cooling aside ) in the lab before sending.
Usually fan cooling useless when we playing sound with this system(1/8 rated power) , only necessary when drive high load constantly, this amp have temperature range about 5-10℃, if the room temperature is 30℃, the amp never over 40℃, this temperature cannot make amp fault or down,if the temperature over 85 ℃ , the amp down after some hours like you said, maybe tas5630 chip heatsink less crowed.
4. You can return the fault amp , we will check the reason and we will bear all the freight. we must know the reason come from.
we think this amp have problems at TAS5630 chip heat dissipation unit, maybe vibration in the process of transportation, sorry for the inconvenience!
Aliexpress record you ordered one g300v33 amp module ,but our stock record list one completed amp, you change your order in the message and pay us addtional money by paypal, so there are no change in the Aliexpress.
Please return the fault amp and we will send one new for you, we will bear all the freight.sorry again.
Can you send me a new amp and A return ems bag?
I have been waiting over 6months for an amp that works now....
You kinda have made me feel like an idiot instead of just listening to me
I have no reason to rip you off I got told sinewave make a good amp and I want a good amp....
We will remanufacture another new amp for you soon, but we don't know your met problems come from where now,only doubt heatsink over amp chip, this is not good way to reslove problems.
so we have to ask u send the fault amp to us and we will test it again and get conclusion, we have declare it is custom-made amp for you and only one amp we have made so far. we are worry about new amp have problems too, so please help us return it to us by EMS or other Express way, we will take some photos for you and get your agreement before new amp sending. we will pay more money and over the amp cost if we do this , but we have to concern about perfect amp for you.please understand and support! never worry about other things, it is very small cost in our company , but it is very biger thing for our customer, there is no reason to rough deal you problem.
We are technology company, only want to make products better! if give us more good ideas we will sucess sooner,we are sorry to take up your time.
Another ideas, if you have some experiences in this area, please help us run this amp and take apart this amp , take some video and help us confirm the problems come from , we will send one new perfect amp to you soon after we get enough message ,about the orginal amp you can keep it as gift.
Hello! we have not receive any message from you, we don't know how to resolve your questions. please let us know soon, we have arrange special engineers and wait to process it, over this week, we will have long time holiday, all the things will be delayed.
Recommand to you arrange things in the work time.
1. help us take some video or photos for the problems.
2. we will confirm the problems and rebuild one new for you soon.
if we without your message reply, we can't start rebuild processing, TKS!
Yerh sounds really good guys, thanks for taking the time to realise my problem!
I will send you a video in the next few days, I have exams now
Any update, we are very busy now, but we have to arrange special engineers to wait to process your problems, please process quickly.
it is very simple, take video and display problems , our engineers will judge where is the problem.
