ebay:Weiliang Dual X2 AK4399 DAC with LCD
so 5 days of burn in is done, HDAM modules compared against OP01 and everything I can say is simple.............I would be repeating myself how amazing those HDAM modules are so I'll be more than happy if someone else could buy it and test it otherwise I will look like an idiot who can hear weird stuff :D
p.s. I'm screwing in top cover means this does not need any additional touches and I won't do any other upgrade, it's finished and I'd like to thanks to all of you who helped :cheers:
Hi all!
my dac is the following:
Finished AK4399 AK4113 DAC Decoder 192K Software Control in Case by Weiliang | eBay
I am using it with a gainclone lm3875 without dc protection circuit or input capacitors.
I decided to replace the ADA4627 (which had already replaced the stock opamps) with the hdam opamps bought from youbuy.
The first impression was very good but i realized that a weird hum appeared when I turned the amp volume up (without listening to music). Believing that it was a gainclone issue, I started searching what was wrong with my gainclone's grounding etc.
After many hours I realized that with the new hdam opamps my woofers were moving back and front when I changed the volume. My knowledge is not deep but I was told that this is a sign of dc offset.
I changed the opamps immediatelty, now back to ADA4627 and everything is fine. Zero hum and the woofers don't move when I change the volume.
Maybe I am the only unlucky here, but it was impossible to keep using the hdam opamps.
Hi Tuxx,
I think that the reason is DC offset. You should disconnect your amplifier, then adjust 0 DC on output of the HDAM modules using potentiometer on the HDAM modules.
I also have power amplifier without capacitors in signal path and everything is fine when I use the HDAM modules.
tuxx: can you let us know how is grounding of this DAC made? I had similar issue due to missing grounding from the main voltage socket, in my AKM DAC I had to even connect PCB separately as the chassis did not pass the grounding properly to the board, I wouldn't be curios if there isn't any grounding or it's not connected properly to the board which is common issue with these Chinese DACs...
