F5 power amplifier
F5
I have a problem my 50A bridges are in short circuit, I do`nt knew why, Any idea?
The amp worked for 5 to 6hours, i have biased the amp to 1,9A the borads are cascoded two pairs at 32+32VDC.
I found R11 & R12.
They are the output's Source resistors.
The current coming in through the top device MUST pass out through the bottom device and what little can pass along the NFB resistors.
The voltage differences you have measured are impossible if the Source Resistors are equal.
Did you match them?
Have you connected something else to the Output node?
