Help for 3 or 4 way loudspeaker
Joined 2009
I wanna know if can go active for the 3er way woofer, I own this active filter:
http://www.reckhorn.net/pages/active-x- ... ssover.php
Isnt modified for high voltage output, the question is: ¿Could I use it for the woofer SB Acoustic?
Also I have a couple of pcbs from a GB diyAudio "My Ref Fremen Edition"
http://www.diyaudio.com/forums/chip-amp ... ation.html
First to make the two ampli I want to know if can be enough power for the SB Acoustic woofers?
...woofer SB Acoustic?
Hi guys,
Try to give here some feedback because I'm not so sure of active systems to help merlin el mago. I'm more used to the passive crossovers.
merlin el mago,
To help everybody with your long thread, give here:
  • The power (RMS) for your amps you are planning to use, LF and HF.
  • Direct links for your drivers or references and type of speaker/size (or post#).
  • Direct link for your HF crossover you are using (or post#).
Regards.
Joined 2009
  • SB23NRXS45-8.pdf
  • ScanSpeak 18W-8545-00.pdf
  • Seas Millenium TCF002.pdf
Joined 2009
I only need advice to know if My Ref. Fremen Edition power amps can be enough power for the SB Acoustic SB Acoustics SB23NRXS45-8 and also if the active Xover http://www.reckhorn.net/pages/active-x-%20...%20ssover.php is ok for the LF Xover for the SB Acoustic SB Acoustics SB23NRXS45-8? If yes after will speak about the cabinet if it's better or not better BR or closed, etec.
The 2 ways & the power amps for the 2way is ok as is.
use minidsp as xover with 150w amp for bass 85-800hz
with alcone 100wrms woofers , 150 w amp for mids , and 12w tweeter amp(tube)
even with a 60w woofer i think you need some headroom on amp power , maybe that 75w amp with be a better choice
dont know how many volt your active xover will deliver to your amps , on minidsp i had to set it to 2v , the default 0.9v wouldnt do
My Ref. Power amps have 40W @ 8 ohms.
That's about what the woofers SB Acoustics SB23NRXS45-8 are going to use per channel (if two drivers) if in a reflex enclosure. That's my modest opinion and I already mentioned that in post#385. :)
The (2) mono-blocks Erno Borbely Millenium 75WRMS class A (I'm not acknowledge in this amps) are also enough for a full range 3-way with the same drivers. :)
wether its active or passive, you still need to perform decent measurements and simulated it.
good target response and good phase behaviour should be your goal.
the sb23 wont play loud comfortably, i would suggest use 2 and tune very low, fb around 27-30hz in a large box 130-150L. even though you prob get better result with sb34nrx in sealed 100-130l
hope that helps
i had a technics 45W amp with jbl 90db speakers , i played the thing so loud , it got so hot you could hardly touch the case near the supply , but it still lives in my sister´s home and plays fine.
so i think the op will regret is choice of bass driver and amp when he wants to listen at loud volumes.
