The CCS works by applying a CONSTANT Voltage to the Resistor.
That results in a CONSTANT Current through the resistor.
Remove the resistor and you remove the CONSTANT from the circuit !
D'oh!
Initial conditions, each triplet dropped 5.7 volts. Vgs was 4.56 and 3.95. But, as I moved Vgs I got unexpected results. Dropping 4.56 to 4.36 also dropped the current through the CCS.
I found dropping Vgs of 3.95 to 3.91 did drop the current in that polarity. Both ccs resistors measure 2.9 ohms.
Is there any other way to get the ccs to match? Perhaps the 100 ohm resistor on the K170 can be adjusted? May a pot at that point?
Thanks for the quick reply. This is a lot trickier than I thought it would be. The work will have to wait until at least Monday, when I am near a real computer.
When you are in ballpark their tanscoductance does not differ without gross Id differences. To bring them absolutely in line is more of an aesthetic thing.
OK, I may start final wiring today, but unfortunately I still haven't gotten any advice on wiring the secondary transformer leads to the preamp board. It seems to be that one secondary coil should have a lead in the center and a lead on one of the outside taps, and the other one should have a lead in the center and a lead on the other outside tap. Does that sound right? Thanks!
I'm seeing about 10.04 VDC (positive and negative) on each rail and everything was good on my first test, no hum, good sound, but then one channel went out.
I'll need to do some troubleshooting here, but just let me confirm first:
(1) On the three "input" connections, the center goes to the ground connection on each channel of my (Goldpoint) attenuator (which is being fed from my input jacks)?
And (2) on the three "output" connections, the center goes to the ground connection on each of my output RCA jacks?
Thanks!
Thanks!
Rare to hear such an error report, not inherent, not a known issue. I would suspect:
-Signal path connections/solder joints/wiring.
-Relay. Tap it with the back of a screwdriver in case it latched.
-Rare to expect a weak JFET in the audio section quad that went out, but touch each of them after system warm up to make sure you got no cold one. Or compare votlages across each.
P.S. The 2K2 is the LED feed/protection resistor of course. That value has been chosen by me on the the prototypes for some subjectively pleasing luminosity. Not same LED not same panel not same distance not same room lights for everyone. You are free to dim yours further with higher value if necessary.
- Analog Line Level
- Salas hotrodded blue DCB1 build
