Rewinding radio tuner string?
Joined 2009
I'm at my wits end trying to figure out how to rewind this radio tuner string on a Philips AZ2000 Radio,CD,Tape player.Any help I can get with this will be greatly appreciated.If more photos are needed let me know.
Joined 2009
Find the service sheet for the radio. That will show you where the string goes.
I have the service manual and it doesn't show a diagram? Ive contacted Philips to see if they had anything like an exploded diagram and they just fobbed me off.They said that it is unrepairable? I replied saying Ive repaired it already I just need a diagram to put it back together.Ive had no reply.
Joined 2009
Ive tried Vintage Radio etc...etc... Ive downloaded a book with 500 odd diagrams of different restrings But this one just had to be different,its got a weird wire spring? that looks like only one string goes on it? I can manage to get it nearly on but I'm scared that Ill break the string if I stretch it too far to get the string over the pulley. Do you think it looks right, I have two winds around the tuner knob near the top between the pulleys? Ive tried three turns but that didn't work out either? This site will only let me upload one photo so Ill upload a detailed close-up next.
A couple of those small pulleys appear like they would come off and a couple appear to have the posts melted so they won't. Might be a clue as to how to stretch it around? Possibly one wrap around the small driven pulley is enough if there is that much tension?
Joined 2009
Ive tried all your suggestions fellas and more but it seems impossible to get it back on? You can see a pin on the end of the spring is locked in a hole so there is hardly any movement? When I put too much tension on the string the tuner board comes out of alignment,it needs to be screwed back down to the chassis but if I do that its upside down and I cant get at it? It must have been constructed by a robot with 5 arms.LOL The photos show one turn on the tuner knob.Looks like I may have to go without a station indicator and drill a hole in the case for another tuner knob?
"You can see a pin on the end of the spring is locked in a hole so there is hardly any movement?"
Yes, I see your problem. It doesn't make any sense. That spring arrangement requires the arm (with the loop) to be able to move widely.
Maybe the vertical pin to the left of the loop is just "parked" in that slot, and needs lifting out into the lower segent. There you will have more tension but greater chord length.
That sort of looks right, but this is a cracking bottle of bordeaux ....
I have to admit I'm somewhat bemused by the spring, it
only makes sense if its bent back towards the back of the
hole /slot and one or both cords just go behind the vertical
drop, I'm pretty (very) sure the cord does not go in the loop.
rgds, sreten.
A clue is the range of movement of the white wheel, you
may have overwrapped it and need more turns on the
tuning knob. My best guess its 180 degrees parallel
to the two pulley's, and you don't need any cord
across the gap, that is the way I'd approach it.
There is no need to wrap the big pulley, the
gap gives the precision of the alignment.
If its miles too long unwrapping the big pulley
wrap all the smaller pulley's or some of them.
Joined 2009
rgds, sreten.
The string will only wrap around the white wheel once each way?I feel like Ive done it every way that I can possibly cut it & dice it. This is doing my head in so I'm giving it a rest for a while,otherwise its liable to end up in the bin.:confused:
Joined 2009
IMO the cord does not go round the white
wheel and that is what you are doing wrong.
The cords go behind the pin in that slot.
From there they go through the gap
and directly to each of the pulley's IMO.
rgds, sreten.
If you mean that it goes on the inside of the white wheel? It wont work whichever way I look at it,there's way too much string left over.
If there is too much left over wrap more on the tuning
knob, and / or wrap one or more of the small pulley's.
It can't be that difficult to get it to work.
The cord has no tension spring, and behind the pin
is the best way of applying tension to it, AFAICS.
rgds, sreten.
