Home Brew PCBs
some of my diy home made pcb
No one is disputing what works for some and not for others, this thread is intended to produce a result that EVERYONE can duplicate.
The photo resist method is the method that is most reliable, doesn't require any magic paper and is 100% repeatable.
Recently available is photo negative film, easily applied with a laminator, eliminates costly failures with expensive photo resist board.
I've been trying it with Caustic soda as a developer which is too harsh, I'm just waiting for the correct developer which is cheap.
Photo resist does require a printer that can produce a good solid opaque image, that can be any printer printing onto acetate. My GelJet produces the best results but so can a decent laser printer.
I have a large Vinyl cutter that I used to use make CD label's with and I also used it to make Patterns to stick on boards for etching and that worked great!!!
Now days you can get a small vinyl cutter rather cheaply ($100 to $200).
I had almost bought one when I discovered the toner transfer method since I didn't have my big one with me at the time.
I still have the big one now but it needs some new rubber wheels so it is not operational at this time.
I also have a medium sized HP color plotter that I have been thinking about some how rigging it up to work as well.
I just recently read an article of someone stripping down an InkJet Printer to print directly on to a board.
It was an Epson CX series printer and I have one of those too that still works!!
There is a 3D printer available in a kit form for about $850 that will do the job and i saw another version that spit out wax on to the board for etching.
Check out the KickStarter website as that is where I saw those devices.
Pretty cool stuff with resources as to where to find or how to make the print heads!!
One other version I saw used a small laser that could cut paper and Balsa wood and other lite material that I am sure could be made to cut some sort of stencil applied to the board just like a vinyl cutter would do.
Hmmmmmmmm................................................
jer :)
Jer, maybe another option would be to print on self adhesive labels stick on the board and then cut out the non-trace parts and strip?
Might be tricky though and the label would have to be 'weather proof' to ensure the adhesive is not a water soluble PVA type.
Suppose it depends on how handy one is with a scalpel to accurately trace the outlines and then peel the unwanted bits away.
That is exactly what I did!!
I cut my trace pattern in the vinyl and then you stick it to a transfer tape. Then you take off the pieces you don't want and stick it to the board, pull off the transfer tape and etch it!!
I was able to scan my image in and I have a tracer program that would calculate the cuts around all of the traces between the black and white shades in the image.
It was a very expensive program for the mid 90's. ;)
jer :)
The Epson R800 will print onto the copper without resorting to butchering, however, even the Epson genuine pigment inks are not water resistant.
I've got an R800 here, virtually unused - anyone can have it for £100. It comes with 7 x brand new genuine cartridges which cost £100 alone.
Man....I wish I had the cash!!! :)
I was looking for one as they are old.
In the hacked up version he said he had to make a print and then bake it and make another print and bake it like 2 or 3 times for it to make a suitable resist.
Repeatability can be an issue there, although I haven't read the whole thing to see how he solved that issue
If I could make the print head work with a suitable ink, I could figure out a way to mount it on either my HP plotter or my Vinyl cutter as it is just a bigger and more powerful plotter.
jer :)
