Instead of posting, I'd suggest you get out a soldering iron, build a circuit, and start experimenting. Then tell us what you built and what you found out.
For me, this preamp for this schematic provides a good sound!
If you need 1Vrms output, I would suggest this tiny modification to your schematic to give you even less distortion. Yes, you can also use DC on the heater but the improvement will be marginal. It will also be much less sensitive to the choice of tube (type and manufacturer).
Martin
Martin
If you have any suggestions about some changes to the schematic go ahead!
We already told you so many times the different things that are wrong with this schematic. If you are happy with the sound from this circuit, that is good for you. But fundamentally there are faults with the design that you have been pointed out to you and which you choose to ignore. That's your decision, but do not post it claiming that it is good. It isn't.
So tell me what is wrong with this preamp, and if you are able to give a better schematic for tube preamplifier or line-stage.We already told you so many times the different things that are wrong with this schematic. If you are happy with the sound from this circuit, that is good for you. But fundamentally there are faults with the design that you have been pointed out to you and which you choose to ignore. That's your decision, but do not post it claiming that it is good. It isn't.
thank you!
Hi,If you need 1Vrms output, I would suggest this tiny modification to your schematic to give you even less distortion. Yes, you can also use DC on the heater but the improvement will be marginal. It will also be much less sensitive to the choice of tube (type and manufacturer).
Martin
To be more precise in the way this tube pre-amp with ECC88 measurements were made with a device CLIO with the input signal of 1V amplitude sine wave of 1027Hz at the 2 harmonic is 0.38%, and 3 harmonic is only 0.032!!
Cheers!
You say this preamp is high end. Please define high end.
Cheers
Ian
Oh no,...
I'm in my way I said it is high-end!??
Oh no?!You say this preamp is high end. Please define high end.
Cheers
Ian
simple....it means high prices....expencive, thats all it says
means its only highend DIY if its very expencive
sound has nothing to do with it at all
piece of cake
Oh no?!
Of course you did. Have you looked at the title of this thread?
Cheers
Ian
Hi all!
E should look like this High-End tube preamplifier with 6DJ8 (ecc88)!
Hi all!
That is not high end.
Cheers
Ian
What is High-End tube pre-amplifier!?
Hi Ian!
Happy New Year!!
At your, what is High-End tube preamp?
Give the schematic, give suggestions,.....
cheers!
Cheers
Ian
Hi Ian!
Happy New Year!!
cheers!
Hi ruffrecords!
cheers!
Define 'high end' and I will tell you.
Cheers
Ian
Cheers
Ian
Very simple ....
High-End tube preamp has it that I did!
Enjoy and cheers!
I agree - thats a terrible design - unless you want high distortion.
The poster has been pointed to a large number of better performance and highly respected times and they keep ignoring them in favour of this type of dross.
This thread is very tedious.
Shoog
Shoog
Then don't respond. This has been going on for a long time.
http://www.diyaudio.com/forums/tubes-valves/237553-diamond-tube-preamp-12au7.html#post3527148
Everybody builds their own equipment. Each one sounds different. We all have a different ear for sound quality. I like all the equipment made on diy audio. It is fun to watch and analyze them all. I have no critical comments about this preamp.
The e88cc is a very nice tube for audio use. There are a lot of different brands of this tube, and they all sound different. Their characteristics are all a bit different.
The power supply is a classic one, it works. The heater supply is good. It is about 60 percent perfected. Learning how to get the next 40 percent is the fun part. It is the fact that the circuits will never be perfect that keeps us dreaming. Striving for perfection. MIke
- Tubes / Valves
- High-End Tube preamp with ECC88
