B600 circuit not tested.
why not test??
B600
Why u not test this circuit Apex Audio ? what special this circuit
Hey.. I want to ask for B500, its normal for 4,7 ohm and 47nF is hot if not connected to speaker ? its that true? please give me some answer.
why not test??
PCB for prototype not finish
B600
Ok. Thanks before Apex Audio. Thanks for sharing. i will keep learn.. and do my own.. great job..
This circuit (B600) have better low end response.
You have some osscilation if 4,7 ohm is hot.
I will try to make the PCB after the end of the year
thanks for ur answer sir, i never get some answer on my indo forum, so i join to this forum and i hope i get some answer here.
Ok sir mybe that right, but what can i do for my problem, i so confuse, if i connect the speaker, this not problem. can u give me some solution? For little info, i use darlington for this amp.
post2768:
is the b120 an inverting amplifier?
Yes it is, B600 use buffer inverter on amp input
Please check
Thanks for sharing...
I'm building B500 right now & not finished yet...
but today I saw the new B600, so here we go
I try to make a layout for this B600, need some check for error
I attach the top & bottom too
PCB size 50 x 200mm
we need two jumpers here for Clip Led & OUT
Hi Mr Daman, I try to design layout for this one. I can send you the .dipwhy not test??
Hi Dear Sir Apex,B600 circuit not tested.
PCB size 50 x 200mm
Hi Dear Sir Apex,
PCB size 50 x 200mm
Nice work, look like APEX
another master piece from APEXaudioB600 circuit not tested.
Can any help me my zobel rc problem without load ? So i remove it, because give dc out, but with load it normal, no dc out on output terminal. Any help please. I use darlington schem from this forum,. Help me.
capacitor in zobel might be leaking or have shorted... replace and check if it helps.
as I suspected, but after I check everything is normal or due transistor pre drivers i put to main headsink make this trouble ? but with load everthing is fine.
- 500W PA amplifier with Limiter
