This was a big debate back in my formative days.The 10u bypass across the LED is doing nothing unless it's an unusually poor LED. Most green LEDs have impedances of under 10R.
Most use(d) a small value (~0.1u) to transcend the
speed of the (usually) Vbe multiplier. Some swore
the larger the better. I use whatever I use somewhere
else in the circuit for economy.
I would use a resistor instead of the LED if the JFET
would act like the current source it should be. BUT
with a resistor I get xover distortion with a heavy
load that somewhat collapses the rail.
Is this un-ideal current sourceness some manifestation
of the "leakiness" ?
It is the clearest amp I have come up with (for my ears anyways)This latest design with 3 fets, 1 jfet and 2 mosfets, is OK, barely. It is simple, almost crude, BUT it should work, and perhaps sound pretty good.
THD ~ 0.06 (FWIW) quasi-monotonic (distortion doesn't go down
with level, but not up either) I attribute it to lack of global feedback.
They are lateral mosfets (negative tempco) They will idle @~ 100mAWhat controls the current through the mosfets? Does this rely on Vth being correct and not drifting with temperature?
(almost whatever you do) Empiracally I've found ~ 1.65V between the
gates works best.
The biggest issue with the lateral MOSFETs in this application is the high and variable gate capacitance. It takes a lot of drive at high frequencies.
If you bootstrap from the output to the drain resistor you would reduce the effect of voltage swing. The cost being an extra cap.
(This feels like working with a China OEM on reducing parts count because a resistor has a cost above zero)
Edde, the Idss of the cascode fet just has to be equal or greater than the input Idss. Whatever the input device can do, the cascode device has to do. IF you use mosfets for the cascode part, like the CTC Blowtorch, then I found that operating at HIGHER Id than the input device is better, because it gives slightly lower distortion.
This simple circuit might become a 'revelation' for you, hitsware. It reminds me of the extremely simple and 'crude' amplifier that Richard Heyser designed at JPL and took home one night in the '1950's'. This is where the idea that global negative feedback is a problem, rather than a solution, came from first. Long before Charles Hansen, or me, even.
Not nearly as bad as IRF types. Way lower capacitance.
I can get a nice 10kHz square wave which is my criteria.
The only drawback (for me) with the laterals is the
relatively high channel resistance (~ 1 Ohm/device)
And extra resistor.
If I bootstrap it ups the voltage gain which I don't want
because the ratio of the source and drain resistors set
a predictable gain. (since the circuit has no global feedback
as is the usual gain setting mechanism)
Low parts count is an aestetic for me .....
And extra resistor.
The laterals really don't need it and I don't like the awkwardnessHitsware, the tempco of the LED will often give you even more temperature control. I use LED's to bias output stages for the Parasound JC-2 preamp, for example.
of making the thermal contact.
( Thats the whole reason I prefer lateral mosfets. Otherwise I'd
use darlingtons )
I have. Measures and sounds the same. For some reason it's habitual.The cap across the LED is mostly irrelevant. Try it both ways.
Based on input from gurus in my past.
If I replace the LED with a resistor, why does the bias change
if the rail changes ? Shouldn't the JFET act as a constant current
source at idle ?
That's fine, but Vth will be all over the place without very careful matching.
For 1.65V, you'd do better with red LEDs- the HLMP6000 would be perfect, very low impedance.
Thanks John.
In this moment I´m playing with another part of Vendetta too.
Green will give you more voltage, usually, than red.
2-2.1 vs. 1.6-1.7, at 5-10mA.
Hitsware, NO MOSFET IS PERFECT. When running open loop, all Mosfets will change slightly with drain voltage. They would have to be perfect 'pentodes' in their output characteristic to not change.
NOT the mosfets ! ...... The JFET
I found these empiracly...........(after trying every diode and LEDStick with what works for you, Hitsware. We can't engineer it from here. Green will give you more voltage, usually, than red.
that RadioShack stocks)
For some reason big green is different than small green.
- Member Areas
- The Lounge
