Have a fun with the son, electrons will be there tomorrow also, no doubt.
Got an IPad to Night at the Museum II, Lego all over the bed, cheese doodles and an Ipad. Could be worse. Yes I did some tweaks to Haflers original. Its in the other thread
Got an IPad
Watch this at leisure sometime then. Similarities in wave behavior Its to know thy wiggles.
Absolutely fantastic guy. Enjoyable and educational to the morning coffee.
Touchy stuff those wiggles. If they don't have their way they pogo dance like Jello Biafra.
As a Young and entusiastic punkrocker I once got an answer to a letter from Jello Biafra. Btw the boating took a hike with an increased GNF-resistor.
Yes Mr Biafra is a real gentleman and had/have real well grounded ideas behind his whole appearance. I will let the amp play and show if its stable a while. I putted 2k4s instead of 1 k. The sound went firmer, more controlled, less wet and fluffy. I'm not yet sure if that is pro or con to my taste
After that some measures
The comp cap is OPT dependant also and I dont have the A-410s in that Hafler constructed the circuit for. I use Z565
Of course its a comp for the total transfer. Surely it takes to measure squares to tune since the OPT is another and the Rfeedback is another.
Yes. Heavy toobster artillery forces are now in trying to guide me on http://www.diyaudio.com/forums/tubes-valves/236527-iso-motorboat.html
Did anybody build or listen to a 6V6 triode connected line preamp? I think it may be interesting to build one since I have some NOS. Maybe SRPP.
Later full schematic
Cathode follower version
A recommended parallel regulator
A recommended series regulator
Salas the link for "A recommended series regulator" doesn't work.
Around 22mA depending on tubes brand and vintage.
Cool thanks Salas, the current is what I was needling to know. I'm hoping to build a pre pretty soon. But I'm going to go with the old school approach with lclc supply filter.
has anyone put a tvc on the output of this? I've got one with a inductance of 20H. I've read the inductance doesn't matter since its a reflected load. But I though I'd ask.
Thanks,
Nick
- Tubes / Valves
- 6V6 line preamp
