Fetzilla Build Documentation
When I build my first FetZilla I had the same problem with that resistor also the first resistor on the positive side of the psu.Turn it off checked the board on shorts,cleaned the board to be shure and never had that problem again.There were other members with the same problem and also the first resistor on the positive side of the psu.Must say (red face)never used the lightbulb tester is this gonna prefent current draw?What wattage of bulb do I take for this tester?
Of this amp both channels R22 gets hot and burns up.
What is the purpose of D1-2 ?
I think these are a protection againt reverse voltages.
I you pull the ground up above V+ or below V- the diodes starts conducting.
If you mount them reverse they conduct and you will draw a fair amount of current from the supply and the output voltage would not go above 0.7V. Maybe you can check this. If the diode burns the problem will fix itself but the protection is gone. But in some cases a diode shorts which will worsen the problem.
My brothers FetZilla
