Funniest snake oil theories
Steve's correct point aside (tarnish of silver is not the conductive form of silver oxide and is generally not even an oxide), the resistivity of AgO is about 60 ohm-cm. That's equivalent to a conductivity of 0.017 S/cm. That compares to 63 million for metallic silver, so the myth is only wrong by a factor of three billion or so.
Silver plated wire is used for RF where the surface conductivity is important. Silver oxide has the same conductivity as silver. See "LITZ" wire. I would suggest it is totally irrelevant to audio, but that is where the snake-oil comes in. You also see silver on all the old JAN-spec type N connectors and BNC's for the same valid RF reasons.
Tin plated wire protects the copper so you don'r get the green growing crud like half the "audio-grade super cables" generate.
Remember, "mil-spec" means ONLY that. It meets a spec. Many of the specs are actually very low.
Its temperature range, for most of the common stuff, both the tin and the silver are used to protect the copper, silver plated with the relevant dielectric used for higher temp applications. It was more a dig since mil spec always comes up as a sort of mantra when esoteric cables are involved, obviously if its mil spec then it adds to the esoteric value.
skin effect/depth at 10khz is 660µm. i would not say silver plating is snake oil
Last time I checked even SACD did not produce VHF 'audio' frequencies - the lowest at which silver plating has any useful effect.
If you do not know why silver plating are used then say so.
If you know - then why not write the real reasons instead of harassing..
There are several reasons why copper may be silver plated.
The most obvious one are when as an example teflon are used as insulation.
Copper start oxidizing at much lower temperatures than the temperatures teflon need to be heated. Silver start oxidizing at a higher temperature than the temperature teflon needs to be heated to..
For mil spec and aerospace cable its the working temperature range....That's why they use silver plated cable, and for lower temp range you use tin plated copper.
We are still waiting for your revelations on the quantum advantages of silver...
Pointing out mistakes or offering a contrary opinion is not harassment.
But why use teflon as insulator? It may be low loss at microwaves and low smoke in a fire, but what advantage does it give for a short audio (analogue or digital) interconnect?
Off line for a day. Thank you FIOS.
Anyway, I stand corrected, silver oxide, or more correctly silver hexasufate or something like that, is a poor conductor. Don't blame snake oil cable salesman for inventing it as I was taught this in tech school decades before that idea ever came to pass for cables.
The old wire-wrap wire was also silver over copper. It relied on the high pressure cut as it wrapped around the square pin for a gas-tight connection. Sounds like it should have just been tin. Litz cable is for HF, and I guess inside the insulation stays clean so it does have an advantage in skin effect. (Useless in audio as was mentioned. We are talking Ghz) Or, maybe that was wrong too! Ya, learn something new every day.
Putting the phono stage inside the table was even better when solid state came along made a lot more sense than silver cables.
Back to tracking down my ground loop or noise issues with my new oppo and Outlaw. Looks like the HDMI spliter is to blame.
Maybe you don't know, but even the color of the teflon affects the sonic performance as the colors are contaminating the pure teflon.
In the 80ties I analyzed and researched the different substances used for color both for chemical, electrical and sonic differences. And differences there are :cool:
