"Diamond" tube preamp with 12au7
Tube preamp with ecc88 (schematic-2)
Hi all!
Can this tube preamp to include of input tube buffer (Figure 1) or earlier should do some changes to the proposed schematic-2?:(:confused:
Thanks for the help!
  • Tube preamp with ecc88 (schematic-2).pdf
Tube buufer excellend!
Hi all!
These days, something I did, and here's the effort ....
What I got beauty, that kind of tube-Sound (high-ended)!
See photos,...Plis comment,...;)
Cheers m-r Ben (00940)
Cheers everyone!
I'm delighted that you took the plunge and built something and even more delighted that you got it to work.
Well done! :up:
Sy, will be true HIGH-END tube preamplifier with 12XA7 (ECC83) - Philips mini watt or,.... presented here!
Cheers!;):cheers:
Hi guys!
I want to create the tube preamplifier or tube buffer under this schematic. If anyone has some schemes comments let go. Any help is welcomed.
Just please tell me what is wrong what's wrong with this tube buffer (preamplifier)?.:confused:
Thank you for your cooperation!
Useless crap. Output impedance >10 kOhm. Wrong tube for this kind of aplication. Don't bother
Disabled Account
Joined 2010
I think,
Its great you made something and have it working. If you like the sound then that's it!
If you are looking for a circuit with 0.000001 % distortion then perhaps its not quite the thing. However the ECC83 has a nice "Tone" and many people prefer the sound to ECC88 etc.
I must admit I did not know quite what you were trying to do, you have surprised me:) well done!
What's the point of a high performance circuit if you don't like listening to it?
M. Gregg
that´s properties of all hi-mu triodes i guess
No, not at all, but you can certainly run them in such a way as to get high harmonic distortion. Run correctly (in the sense of trying to minimize distortion), high mu tubes like 12AX7/ECC83, 6AQ4, 7788, 6SF5, and D3a have stunningly low distortion. There are probably high mu tubes out that that don't (12BZ7 comes to mind), but most of the ones I've tested are quite clean.
