Not anytime soon, we have a lot of boards. It should be easy enough to go to 2 wires from one. Worst case you have a solder buss bar or a single turret. Or if no ones looking twist the second wire onto the first, solder, then cover with shrink tube! If you can't figure that out you shouldn't try to build it!
But yes, it would be neater with more holes.
I call those wire clamp busses "Euroblocks" Not sure if that's official!
Gents
Actually they're Pheonix terminal blocks.
Available at most distributors.
Example; at Mouser, part no 651-1729128
Rated at 13.5A 250V
Rated at 13.5A 250V
Toecutter! Wonderful to see you here again!
Thank you very much for the part number! That will save lots and lots of headache!
Gents
Rated at 13.5A 250V
Our long lost member of the flock has returned!
Glad to have you back, we missed your input! Hope everything has settled down in you life and things are good.
(I just knew you were MIA, don't know why) (not asking either)
Very good to see your post. I had to do a double-take? What, what, what?
UK toeCutter? Hooray-beer!
Ron
I can relate
You know it's said Thomas Edison had 999 failures before he got it right ONE time,lol,I would have probably gone crazy long before that,but what patience and perseverance,
Hang in there it's on the up and up now!
NS
You know,
Sometimes things go bad and then they go real good.
I've had a few of those ups and downs over the last year but now all is good.
Really exciting stuff going on here and the store boards and chassis' look magnificent!!
NS
Hi UKTocutter,
Check out these boards they are almost ready to get in the box,They have played and sounded great too!They will be water cooled for the Bigfets the MUR's don't seam to get very hot so they will have standard heat sinks,Gets so hot here in TEXAS got to put water on them,lol.I cut some server copper heatsinks in half and covered them with sheet copper and run 800 gph with a 10 gallon Reservoir,I have a 50 watt F5 setup like this now,haven't had to add a radiator yet,but it's coming,lol.
NS
NS
Hi Toe Cutter,
It's a good time I'm in San Antonio, Houston is a fun town enjoy! ,it's been in the 90's during the day but the nights have a nice cool breeze makes it nice outside for some Grilling and beer,lol
A HAPPY 4th TO everyone!GOD BLESS our troops!
PEACE
NS
HI,Hope it's not TOO hot in Texas as I'm flying to Houston in the morning!!!
PEACE
NS
What did you use for th3 2SK170 and 2SJ74???
I purchased these boards, F-5 Clone, recently and cannot seem to find these transistors OR a drop in replacement? I have been all over the Net looking for these. Ones from China, NA.
Paul
Hi UKTocutter,
NS
Paul
Paul
Which transistors are you talking about?
It's in his header - the J74 and K170.
Buy from member " Spencer " (FET Audio | Hi-End Audio Projects) He is essentially the only reliable source of the genuine devices anymore.
Assume everything on Ebay is fake.
- F5 Turbo Circuit Boards
