take a few of those fine 2SA1095 / 2SC2565 ringemitters
Trouble with those nice A1095/C2565 is that they're obsolete since 1988, aka for the last 25 years.
Trouble with that is that in 9 of 10 cases, the fine ringemitters on offer today are fakes.
In your case, a faked power device package with a decent size die inside, but unlikely to be in the 60/80MHz fT range.
By the time someone else would be ready with your amp, he would likely have spent more than a secondhand set of Linear Acoustic LA60's cost (which include a pair of nice original ringemitters per monaural)
And judging by a glance at both your amp case and PCB, money better spent.
VSSA/PeeCeeBee Chassis
My new "compact" chassis, intended for my version of Lazy Cat's VSSA, and Shaan's PeeCeeBee.
Still a work in progress, so, suggestions and comments are welcome. Heatsinks from Heatsink USA, an advertiser on diyaudio.
All other parts made from flat pieces of aluminum, SS top and bottom, except for the heatsinks, basically made from parts from the scrap barrel...
I am also hoping to make a bit larger version for Bonsai's nx-amp.
@sakis, if you are reading this, the heatsinks are rated at about 0.65C/watt, and can be thermally coupled to the front and back plates, intended for 8-ohm speakers and a temp rise of about 25C above room temperatures.
I would like to, at least for the through-hole version, but I am not sure how well it would work. The chassis was designed with volume control in mind, but making a face plate without one would not be difficult.Impressive, PMI. So you are going with passive preamp?
link to the box I used
#2107 2 Full aluminum Power amplifier chassis/AMP case Enclosure / (include terminals)-in Amplifier from Consumer Electronics on Aliexpress.com
Not even $40,- for this beauty. There are, however, LOTS of interesting cases:
#32010 Aluminum enclosure / Power amplifier case/ amp chassis DIY BOX-in Amplifier from Consumer Electronics on Aliexpress.com
chassis 4307 iron aluminum mixing amplifier both sides of the computer case metal alloy cabinet-inAmplifier from Consumer Electronics on Aliexpress.com
S 2607 All Aluminum amp Enclosure / mini amplifier BOX/ PSU Case #0508 9-in Amplifier from Consumer Electronics on Aliexpress.com
Measurement 320 x90 x300 small aluminum computer case amplifier board amplifier computer case-inOther Consumer Electronics from Consumer Electronics on Aliexpress.com
2013 new Aluminum 2109 amplifier computer case free shipping by FEDEX-inComputer Cases & Towers from Computer & Networking on Aliexpress.com
Have fun in checking them out!
Timmo.
Timmo.
fakes?
@ Jacco Vermeulen:
"In your case, a faked power device package with a decent size die inside, but unlikely to be in the 60/80MHz fT range."
So you think these are fakes? For 100% sure: these are the real ones. Not from China, and not from eBay. If you look hard, you'll find them. You are right however in saying 9 out of 10 are fakes. Unfortunately, I have 40 each of them also, but, the best is: I have around 70 pairs of the ORIGINAL ones
(by the way: I torture-tested a pair of these fakes: 2X 60V stable rail voltage on a single pair, and a 4 Ohm loudspeaker, driven to clipping level: they SURVIVED. Good fakes this time... amplifier effortlessly did 100kHz).
@ Jacco Vermeulen:
source for original 2SA1095 / 2SC2565
Hello Jacco,
here, you will get the original ones:
GES GmbH - www.Electronicpool.de - obsolete or hard-to-find electronic components
They have the 2SC2565 as well... on -O and -Y!
I asked for pictures from the 2SA1095-Y, I got them, and... they are for sure original! I recognize them from ten miles away now
Price is quite stiff: you'll have to pay around EUR 20,- per piece.
Timmo.
Hello Jacco,
Timmo.
325addict it's from Tang Hill International in Taipei it costs about $130. It's actually a Erno Borbelly amp case. If you order one, make sure it's the stereo version.
Hi Bonsai,
When will your HiFisonix.com webshop be in working order so we can place orders?
Do
SARA high performance audio amplifier
...... my new project SARA high performance audio amplifier ,schematic designed by Lixandru Dorin and PCB designed by me ......
Regards ,
Alex
Regards ,
Alex
@pinnocchio: Bonsai has a thread where he is encouraging the rest of us to build boards from his schematics and layouts. Everything is there, basically. I posted there a couple times. Not a very active thread right now, not sure why.
http://www.diyaudio.com/forums/solid-state/236522-sx-amp-nx-amp.html
I plan to order boards from the layouts he has provided to us (very generously I might add), sometime this week. You or anyone else is welcome to help, or comment.
Hi Bonsai,
Do
Pinocchio,
I will take that page down. I am traveling too much on business these days to be able to offer a good service.
I will put the sx- Amp boards up soon as well. Please feel free to build. Any questions from your side, I will try to answer.
Looking forward to building it... I probably should build your Class A first, but the nx-amp looks too good to wait. I am surprised nobody jumped right in front of me when you posted the layouts...Thanks PMI - wishing you good luck on the construction. I am very kean to get your impressions on the sound.
New Preamp in the works
Here are some pictures of a new preamp I am working on. These are the boards, and let me stress, they are protos, so there is probably going to be changes etc based on what I find. Basically, 6 inputs all with jumper selectable 20 dB pads, a phono input which can be selected for either MM or MC (board still to be designed - this will be a follow-on sub project) and a single tape loop (buffered class A). It has switchable Baxandall tone controls (+-12dB at 100 Hz and 10 kHz) and a class A headphone amp running at about 200mA Iq. All the inputs selection, muting etc are handled by small sealed gold contact Omron relays. All the gain stages are on separate little boards using opamps biased into class A and can drive c. 500 Ohm load in class A to 20V pk to pk. The feedback network source impedance is around 150 Ohms for low noise on all the gain blocks. I am temporarily using a 5k Alps log pot. The final iteration will use a 24 way switched 1k log pot - I have sourced one but its about $240. Pleasure and pain go together they say and this is the proof!
I have targeted something around -110 dB for S/N which I think is good enough, and I put lots of effort into lower distortion which will be very low in this design - sub 1ppm across the audio band at 3V pk into 600 Ohms and less than about 3ppm at 10 V pk into 600 Ohms. I have put the gain elelemtns on small boards because I also have a discrete JFET gain block on the drawing board so that later if I want to, I can use those instead of the opamp based gain blocks. The intial version uses 4562/49710 opamps, but because they are socketed, I can just plug in another opamp to try it out. There space on the gain block boards for comp caps from pins 1-5 or 5-8 to accomodate the various opamp formats out there for the single devices - duals of course dont have this option.
This design uses classic signal chain design - so no active volume control or anything like that and there is no microprocessor in this design - it is 100% analog.
Anyway, still a long way tp go, but I'll keep posting very few weeks.
Hi PMI,
Sorry, just saw your answers. I would be interested in some boards but will go look at the thread.
Do
Pinocchio,
Thanks for this beautiful work!
Do
super target.I have targeted something around -110 dB for S/N............- sub 1ppm across the audio band at 3V pk into 600 Ohms and less than about 3ppm at 10 V pk into 600 Ohms.
1ppm THD @ 3Vpk is roughly the level of 0dBfs from digital sources.
3ppm THD @ +10dB above maximum likely signal is very good.
Achieving both of those into 600r is exemplary.
The trick is to bias a good opamp (and you have to be using something good like a 49710/4562 - otherwise it just won't get you to 1ppm or better) into class A, and then buffer them with a class A output stage. Class A also confers advantages in supply rail harmonic content which helps with the overall performance. I also spent many hours on the layout because there's all sorts of opportunities for common impedance coupling that would undo efforts elswhere. My straight buffer (I wrote about this in 2010) got to 1.5ppm and really may have been lower but the AP SYS272 can get to -114dB (I read in some places -119 dB) and not much lower. I dont expect the discrete version I am working on to reach these levels, but from initial investigations, 2ppm seems acheivable. Anyway, I dont want to hog the thread - this is about pics!
That is! Bravo Bonsai! Potentiometers (see voltage dividers) from 1.5K and above "infect" the linearity of the following stage.The final iteration will use a 24 way switched 1k log pot - I have sourced one but its about $240. Pleasure and pain go together they say and this is the proof!
Have you possibility to try these new LME49990? I ask you because are offered only in SOIC package. I am amazed from their performance!The intial version uses 4562/49710 opamps, but because they are socketed, I can just plug in another opamp to try it out. There space on the gain block boards for comp caps from pins 1-5 or 5-8 to accomodate the various opamp formats out there for the single devices - duals of course dont have this option.
Congratulations Andrew for your new work! I am sure that you will obtain your target of a so high performance!
On my side I find that OPA 1611/12 or the Jfet version 1641/42 to be killer opamps.
Do
- Post your Solid State pics here
