Ok finalizing it now....
There is two more pcbs to done for this amp
Yeeep that will surely follow soon....
Do you have the datasheet of the recommended 40A relay for protect?
Relay from your post #41 will be OK.
Ok thats good coz i have the macros ready of that relay and if you have even just a sketch for the component layout you preferred that will be much helpful for me to draw faster .
regards,
regards,
Ok , I give you sugestion tomorow.
Here they are....
Can you shift the 2sa5200/1943 a little closer to MJL so that all big trannies have equal distance?
Ok there you go....
hi apex, thank u for the such a high power class ab amp for diy.
hi willjj78 well done for the pcb design, good job.
can u share the top layer of this in pdf.
which software u use to design this pcb?
Thanks Nazir...I'm using Sprint Layout 5, here's the file.
thank
thank you very much, very cool design
Apex, post181.
The relay driver should be saturated to operate properly as a switch.
It is normal to use a sat hFE of around 10 for this duty.
I would aim for a base current coming from the EF of around 4mA, for a 40mA relay coil.
The 10k in the collector of the EF is far too high.
thank you all rekan2 apex and here I also want to try the apex BA 1200 need how many amps it transformers?
Use 2x75vac/10A transformer.
Apex, post181.
Thanks, it's my mistake resistor is 1k not 10k.
does any of you have experience with connecting two trafos in series ?
thought I could use one trafo for each rail ?
they are older IE core trafos with 3x 33V
supply caps would be 100V types
That's possible... I even did it with 6 toroids in series with 29vac each..
See photo 4 of them in series...
- 1000W Simple PA Amplifier
