Sorry but I don't understand your problem.
The production of the dac modules goes on.
No problem at all if he can continue with production. What I don't want is: couple of months down the road, because of IP, this to be a problem.
having difficulty understanding, Is this DAC a cloned product, I thought it was audiodesign and Quanghao that came up with it together.
Want to correctly support intelectual property as well as diyaudio community. Please let me know as I am interested in one of the DACs if anyone from the group buy list drops out.
Thanks, John
Thanks, John
...I thought it was audiodesign and Quanghao that came up with it together.
That is correct. I don't know the exact details, but his "lock-out" is unrelated to his work on this DAC.
Good to know .. do you know the thread that caused his lockout?
Quanghao, this is the third time I've asked that you respond to a message I sent you regarding a mistake you made in your list of paid vs unpaid members. Please respond asap.
I think getting locked out of his account also prevents him from replying to your PM
Hi this type of displays look nice also
2013 New Version Yulong Sabre DA8 DSD 32bit 384kHz DAC Decoder Amplifier | eBay
What about opamps. Do I need Single or dual ? How many do I need ?
The op-amp output stage of this DAC use 2 x dual op-amp for each channel.
I have used a dual OPA627 module as first and OPA2134 like second.
Otherwise you can use 4 x OPA2134 or any other dual op-amp.
Thank you ! Then I will use 4 x AD 8620
Oh I forgot it can only be used up to 12 V .
Bought 4 x OPA 1612
Burr Brown OPA1612 Soundplus High Performance Bi Polar Op Amp SOIC 8 Pin Package | eBay
- More Vendors...
- Quanghao Audio Design
- DAC-END R (ES9018) full assembled board
