AB100 Class AB Power Amplifier
Has anybody looked at this and updated it to more modern (available) parts?
It's still an awfully interesting design... we shouldn't let it wither away.
I'm going to bump this thread and hope we get some more interest in it. I have found myself playing with an old Soundtream D-200 amp that I picked up with a dead power supply and it got me thinking about this thread again. I still have a great big old Threshold chassis with massive heat sinks just waiting for the right project.
6L6
Moderator
Joined 2010
I think if this is pursued (and I would love to see that) it should be made on the UMS and all on one PCB per channel.
The New PSU board will be great for it, and it would be fairly easy to get it all together and going.
I still think the most logical place to start is determining what would be the logical (and easy to get) modern transistor substitutions. I know absolutely nothing about that, is there anybody who has knowledge in that area willing to take a look and make a list?
I remember looking at what I had in my parts bin when nelson first published this.
And I came across a few denon recevers 8yro or so. And they had darlingtons that would fit the bill.
I can send you guys the sheets on those. You can decide if they are good or not. All I could decide if they wouldn't let the smoke out that's as far as I got.
The one and only
Joined 2001
There is the 50 amp rated MJ11032 and MJ11033 devices in TO-3 style. not sure if the specs are in range. only 120V rated devices however. Might be good for my old Threshold case. build a 200wpch balanced output version.
I should think they would do the job, and fewer of them.. Of course you
don't at all have to use darlingtons. It's trivial to put together a driver stage.
:cool:
Ex-Moderator R.I.P.
Joined 2005
maybe I could try it, starting out small :p
Conjoined Twin diyAB100s
The attached image [SimpleAB100.jpg] shows two simplified schematics of diyAB100. The schematic at the bottom of the view is a further simplification of the top one. I am able to carry on the conversation without showing the output stage to enhance clarity; because the phase of the half shaded sine wave signals is identical in both schematics.
The second attachment "ConjoineddiyAB100s.jpg" is a proposed schematic for the balanced amp. The Right and Left channels are the highly simplified bottom schematics in the previous image. The general benefits of balanced designs are well known. My primary focus is to show the additional performance benefit from "conjoining" the two amps beyond the established ones of balancing. The operation of this balanced amp is very much similar in concept and application to that described in the patent US 5,376,899; inventor Nelson S. Pass.
The Left and Right amps are joined at the emitter ports of Q6 and Q6'. Jumper J can be a wire, a high quality coupling capacitor or a resistor.
The post to follow will explain the operation of the balanced amp in more detail.
Best regards.
