I've just changed the power supply my M2tech Evo with LifeP04 and i'm getting such goosebumps listening to Souad Massi's Live album that i'm wondering if i could also power the 32 digital section with the other pack. It's rated 9,9V -I've measured it at 10,45V fully charged. Is it safe or over the SOR?
After 3 years I have finally finished my buffalo32s. Last week the custom frontpanel from Modushop.biz/Hifi2000 in Italy arrived. Beautiful work by Andrea Bettazonni. Now it not only sounds great, but looks great as well (in my opinion at least)!
Scanspeakman
Scanspeakman
It certainly looks great.
May I ask how you mounted the display to the front-panel?
I plan to do something similar, but actually i have no clue on how big the rectangular hole must be, to look "professonal". I guess it must be slightly smaller than the display itself...
Also: Should one use a cover glass before the display (for protection)?
I can manage some wood- and also metal-work, but this task does puzzle me.
Bellissimo! Did you use an arduino for the display?
Thank you. I did not use an arduino for the display. It is a custom solution designed and made by my brother to control the i2c bus. The plan is to add volume control by the remote as well. Now only the source selection can be done by the remote.
Scanspeakman
The panel itself is 10mm thick. On the rear a 8mm deep cavity is made, which is slightly bigger then the cut out on the front, to hold the display window. I have used 3mm thick grey plexiglass for the window and made a "mask" of black cardboard so then nothing else then the display is visable through the display window. Around the cavity on the back there are 4 m3 threaded holes to bolt the display pcb to the frontpanel. Easyist solution I could think of.
Scanspeakman
I have volumite with buff32s. When volume knob is turned completely down I still hear music. Is this normal?
I've only recently added the volumite, but strangely I don't seem to remember it being like this when I first installed it. Its now when testing a new amp that I noticed it.
Edit: Another thing thats been bugging me. The spdif button has two positions 1 and ON, so then 1 is off? I am to use i2s input.
I actually think that DAC is some of my best work, and I am seriously thinking of bringing it back, but slightly revised.
I was poking around inside of mine earlier today and I'd say this is spot on, it's a great all-in-one.
A drop in revision (with say, onboard tridents) would be very cool
Help with a Buffalo 32s channel not working
One channel of my Buf32s is not working.
I've tested the outputs (both channels) with an oscilloscope. I have used a CD track with a 1kHz signal and one channel shows the signal ok, as it should be. However the other channel shows no AC signal, instead appear 13.8Vdc between + and GND and -7.9Vdc between - and gnd.
Seems clear that the analog part of the buff32 is failing . Could someone please help me?
Since the scheme is not available I guess Brian and/or Russ would know with more certainty that may be failing.
The configuration of the dac is very simple. I use spdif input and SE output (signal taken from + and gnd) and two Placid BP one per channel (+/-15V and 200mA supply current configuration) and one Placid for Digital (5.20V and 200mA supply current configuration) . Attached is a pic of the dac.
Russ, please do not forget my question...That's a nice clean DAC. Good work. My suspicion is that an op-amp has gone bad. I am out of town at the moment, but when I get back I will try to help you identify which one by giving you some test points.
Cheers!
Russ
- More Vendors...
- Twisted Pear
- Twisted Pear Audio - Buffalo32S (ES9018 DAC)
