My class D amp
Hi Aman,
Congrats, You are using AUD600 Rev1.0 and its fsw is @400KHz so you need 18uH,22uH or 33uH coil. 22uH is best for sound quality.
@Raj,
it is not 104(=100nF) caps use 100pF or 220pF/2Kv
MANOJ
Okay, I will use those caps to minimize resistor heat.
A good news, my t106 & t157-2 cores will be at my hand by Monday. It's from micro metal, I will start this project once again.
One thing, can I use micro to generate oscillating pulse instead of rc?
Thanks Manoj for your cordial support.
Raj
Hi Raj,
i use T157-2 @40uH for fsw=@250KHz i like this freq.
(cal. is N^2*AL)
N=54Turns
AL=14
54*54*14=40uH
if you want to use this fsw(250KHz)and 40uH coil you need little changes at tlo71 ic circuit
MANOJ
Hi Manoj:
Higher freq = better sound, right?
250KHz is good for all range or for sub only? If I want to use this in your v1 design what change I need to do?
Raj
Hi tekko,
this is not true.10 times higher than audio band is better for any good designed class d amp
so 200Khz is enough for all band. and 300KHz is max.(today's components for higher output)otherwise efficiency will be dropped.
MANOJ
Hi Manoj:
What is the relation between fsw, lc? I mean if the fewq is x what will be uH and cap value with inductor?
Raj
Hi Manoj:
Hi Raj,
i don't understand what you ask for?
2nd order LC filter you are calculated only for cut off freq. only ; but in sigma-delta filter coil is also one of the part related to the fsw.
so fsw=300KHz to 400KHz use 18/22/33uH coil depends your speaker impedance
MANOJ
RM 10 on aud600.
hello sir i m using RM10 on ur amp.. amp is working good.but on 110vc dc( testing ) fets geting hot .. using 23uh . i m not using 7806 i m using 7805 . is that any problem ??
Hi Raj,
MANOJ
Hi Manoj, you got it right. I wanted to know at what fsw what will be the L value, C value & Spk impedance.
Is the any chat of this? Or equation?
