I have a subwoofer cabinet that I've had for years which I never used due to a change in plans. The cabinet is very sturdily constructed (1.5-inch walls and 2-inch baffle) and has an internal volume of 4.27 cubic feet (121 liters), and doesn't have any opening cut in it but I'm willing to port it if necessary. I've decided to use this cabinet to build the best subwoofer possible for primarily listening to music (90%) and watching some movies (10%), with the only stipulation being that I'm limited to using 12-inch driver(s) due to the placement of the bracing. I would appreciate suggestions that anyone here can provide on driver(s) choice and port configuration for ported subwoofer designs.
jazzcyclist,
constraints:
4.27 cubic feet (121 liters) internal volume
12-inch driver(s)
8 Ohm
Sealed (F3/freefield<40Hz):
TANGBAND WQ-1858
ROCKFORD FOSGATE P1S812
ROCKFORD FOSGATE P2D412
SOUNDSTREAM R1-12
ROCKFORD FOSGATE R2SD4-12
WAVECOR SW310WA01
SB ACOUSTICS SB34NRX75-6
DAYTON RSS315HFA-8
PEERLESS XXLS12 830845 or XXLS308 SWR 51
JBL GT5-12
CERWIN-VEGA VEGA 124
JBL 2213H, JBL 123-A
MONACOR SPP-300
PEERLESS 830669 - SLS-315 (also Peerless 831857, look on ebay/discontinued)
MONACOR SPH-300KE
SB ACOUSTICS SB34SWNRX-S75-6
JL AUDIO 12W6V2-D4
DAVIS 31ST12M
JBL 125A or JBL 127A
MONACOR SONIC 12
EMINENCE LAB 12
EMINENCE ACOUSTINATOR N2012-8
VISATON W300
CIARE HW 320
PEERLESS SLS12 830669
/next ported(cont.)
constraints:
12-inch driver(s)
8 Ohm
TANGBAND WQ-1858
SOUNDSTREAM R1-12
WAVECOR SW310WA01
DAYTON RSS315HFA-8
JBL GT5-12
MONACOR SPP-300
MONACOR SPH-300KE
JL AUDIO 12W6V2-D4
DAVIS 31ST12M
MONACOR SONIC 12
EMINENCE LAB 12
VISATON W300
CIARE HW 320
/next ported(cont.)
Two more questions:
1) What are the advantages and disadvantages of passivle radiators vs sealed and vented?
2) Would two woofers (10" or 12") be feasible in an enclosure this size, and if so, would it be better to mount them on the same side, or would opposed firing be better?
If you are looking for hifi, what's generally said is that sealed units respond very well (in the home environment).
In this case no need for a passive that is a form of the vented system.
""Would two woofers (10" or 12")...""
What do you mean?
I recommend the TANGBAND WQ-1858
I can look at it if you want...
What do you mean?
As you requested I compare 3 of the drivers for a starter.
Explain for the forum what type of setup you have or planning, amps and the like, main speakers...
1. and 3. are aluminum cone, 2 is a paper cone.
Number 2 has a better sensitivity. All in all they are very similar.
TANGBAND WQ-1858, VB = 120.0 L, QTC = 0.648
SB ACOUSTICS SB34NRX75-6, VB = 120.0 L, QTC = 0.738
DAYTON RSS315HFA-8, VB = 120.0 L, QTC = 0.687
Another very nice driver CSS TRIO12
Creative Sound Solutions TRIO12 Subwoofer
CSS TRIO12, VB = 120.0 L, QTC = 0.597
2. SB ACOUSTICS SB34NRX75-6, VB = 120.0 L, QTC = 0.738.jpg60.3 KB · Views: 725
SB Acoustics SB34NRX75-6 12in Woofer_sb34nrx75-rear.jpg131.3 KB · Views: 751
Well, I'd probably go for the McCauley 6232...
5. Mc CAULEY 6232, VB = 120.0 L, FB = 26.0 Hz (int. volume/tuning), F3=36Hz/26Hz in room, max. SPL 1.00m/118.1dB
McCauley.com : Products: Components > 6232: Overview
6. EMINENCE DELTALITE-II 2512, VB = 120.8 L, FB = 28.9 Hz (int. volume/tuning), F3=42Hz/31Hz in room, max. SPL 1.00m/114.5dB (price)
Eminence Deltalite II 2512 Neo 12" Driver 290-593
7. ETON 12-680-62 HEX, VB = 120.0 L, FB = 23.0 Hz (int. volume/tuning), F3=31Hz/23Hz in room, max. SPL 1.00m/111.2dB. Very low extension, can work in smaller box to 84.6L.
The Madisound Speaker Store
The McCauley 6232 looks very good in a BR box 97-120L and has very nice SPL.
What are you thinking?!
7. ETON 12-680-62 HEX, VB = 120.0 L, FB = 23.0 Hz, 87 dB2.83Vm. F3=31Hz F6=23Hz F12=18Hz F24=12H.jpg56.1 KB · Views: 55
6. EMINENCE DELTALITE-II 2512, VB = 120.8 L, FB = 28.9 Hz, 91.3 dB2.83Vm. F3=42Hz F6=31Hz F12=22.jpg55.4 KB · Views: 60
5. MC CAULEY 6232, VB = 120.0 L, FB = 26.0 Hz, 88.9 dB2.83Vm. F3=36Hz F6=26Hz F12=20Hz F24=14Hz .jpg55.1 KB · Views: 71
Sorry I had to delete this post for a 15" driver.
This thread it's only on 120 L/12". Thank you.
Inductor, you seem to really know what's out there. Do you have a recommendation for a 12" for a 2.5^ft (71 l) sealed box? Sensitivity should be around 85 dB. It must be flat to 500 Hz or so and go as deep as possible. Thanks!
Here's one I found: Bravox EXS12D-2 Extreme Duty 12" DVC Subwoofer 2 Ohm Per Coi 269-531
1. DAYTON RSS315HF-4, 70 L, F3 34.5, SPL 89.4, SPL/MAX 108.9
Dayton Audio RSS315HF-4 12" Reference HF Subwoofer 4 Ohm
Dayton Audio RSS315HF-4 12" Reference HF Subwoofer 4 Ohm High Fidelity Reference Series 295-464
2. SCANSPEAK 30W/4558T00, 70 L, F3 35.5, SPL 91.3, SPL/MAX 105.4
http://www.scan-speak.dk/datasheet/pdf/30w-4558t00.pdf
3. DAYTON DCS305-4, 70 L, F3 37.4, SPL 90.9, SPL/MAX 105.2
Dayton Audio DCS305-4 12" Classic Subwoofer 4 Ohm
Dayton Audio DCS305-4 12" Classic Subwoofer 4 Ohm 295-204
Fair enough.http://www.diyaudio.com/forums/subwoofers/231830-new-woofer-old-speaker-infinity-rs-2-5-a.html
BTW, all three of those are too sensitive. 85 dB is the target. Sorry for the hijack, carry on.
After much deliberation, I've pretty much decided on using two DAYTON AUDIO RSS315HFA-8 subwoofers in a sealed design based on the advice of one of the folks at Parts Express. However, I noticed that this is the same two drivers that are used in the Dayton Audio RS1202K subwoofer kit, which comes with a 2.1 cubic-foot sealed enclosure (about half the volume of the enclosure that I'm using). Furthermore, WinISD calculated a volume of 194 liters for this design. What am I missing? Does the opposed-firing design of the RS1202K make this smaller volume possible? I just want to make sure that I have the right information before I make a purchase.
Also, since I don't want to use a plate amp, what would be a good amp for this subwoofer application? Would a pro amp like one of the Crowns or Behringers be suitable? I already have an Audio Control subwoofer crossover, but don't some of the pro amps have built-in crossovers?
(2ft³ = 56.634L)
DAYTON RSS315HFA-8, VB = 56.6 L, QTC = 0.821, Fc = 37.6 Hz (resonant frequency)
(194L = 6.8510ft³)
DAYTON RSS315HFA-8, VB = 194.0 L, QTC = 0.634, Fc = 29.0 Hz
(4.27ft³ = 120.91L)
DAYTON RSS315HFA-8, VB = 120.9 L, QTC = 0.686, Fc = 31.4 Hz
Dayton Audio SA1000 Subwoofer Amplifier Rack Mountable 300-811
(194L = 6.8510ft³)
(4.27ft³ = 120.91L)
Are you sure it's not a passive radiator and it's 2x drivers?Does the opposed-firing design of the RS1202K make this smaller volume possible?
If using 2 drivers always make space for double air space.
In this case 2.1 cu. ft. sealed cabinet will be half size for each driver (~1 cu. ft.) with high Qtc
Dayton Audio RS1202K 1000 Watt Dual 12" Subwoofer Kit 300-766
Based on the description, it sounds like two subwoofers, not a subwoofer and a passive radiator.Are you sure it's not a passive radiator and it's 2x drivers?
- Subwoofers
- Subwoofer cabinet advice
