500W PA amplifier with Limiter
its mine, b500 tef with 3 pair
Again, thank you mile
Just finish build another 3 B500 amp. So amazing, i don't have any difficulties to finish this amp. Again thank you so much for sharing your knowledge.
Warm regards from bekasi indonesia
Gassanov fuad.
Hi sir mile....can i use 2 B 500 (bridge mode) to drive 8 ohm 18inch subwoover?
How much safety vcc for this amp, 55vac (76.5 VDC) is enough for BTL mode?
I need 1000 watt 4ohm amp to drive this sub. Thx in advance
Warm regars
Gassanov fuad
Bekasi indonesia
B500 in bridge mode can work only with 8 ohm load, for 4 ohm you must use 8 pairs of outputs instead 4 pairs per channel.
Wow thx for super fast respons. What i mean is, i use 2 b500 in bridgemode to drive single 18inch 8ohm subwoofer (not 4 ohm subwoofer).
So my calculation is. B500 work in 500watt 4ohm in btl mode so dual b500 will give me 1000 for 8 ohm. Correct me if i,m wrong.
Thx
