Krell KSA 100mkII Clone
Check the datasheet!
There's no way that 50W device can handle 300W, not even for 100us.
apologies, I was looking at the outputs datasheet:eek:
The driver will handle near an amp at this voltage.
With the outputs having an hfe of 40 at 60v, this driver could push 4 output transistors to 20 amp and only be required to deliver 500mA. To me this is seems quite doable. Is my math right?
Why would you want to double the output transistors for this amp when this amp as designed was able to drive the Apogee Scintilla at 1 ohm loads???
I would think that it would only be required if you wish to increase the supply voltage,but then the whole amp should be somewhat redesigned and optimized.
One of the reasons this amp became legendary in it`s ablity to drive safely 1ohm loads is the fact that it uses two drivers per bank..
So is it possible to double transistor amout? Or if I do that should I add more driver transistors? I have JIM's PCB so It seems to be quite easy to just add (double them too) more drivers to backside of PCB to help drivers load?
Hi Jushota,
I think you could, but for what gain?
if you tell forum members what you are trying to achieve you may getter better advice.
Just a quick post, and a hello !
My amp still works fine and I used it for many many hours.
Still impressed.
Might build another... :)
Hmmm, "might build another" I like your idea :)
Finally, I have started to move forward with my own projects.
This night I managed to get one main board to work. I just connected the finished board to the DC power source and checked with 2 x Amp meters
for to have control over current/power drawn. It looked fine in the very first and I checked the DC output. I had to trim the bias pot to max bias for to get some current readings. At the maximum bias set it draw only 83 mA and the total power was calculated to be approx 9 watts. But that was enough for to check everything, also the functions.
No DC on output, OK. Then I installed a resistor, 4W/1 kΩ paralleled over the output and GND and then I connected a function generator to the input
I checked with a sin wave at the first and everything looked good so far.
At a frequency of approx 170-200 kHz the output swing started to go down but that was Ok if taking to account the feedback capacitor
Then I also checked with a square wave and that was really good. I was a little bit curious of how it should behave if driving the amp with a square wave. And there was no surprises to see...
This main board was the first one ever checked and tested so from my point of view it looked promising for the 5 left..... I have a total of 6 main boards :rolleyes:
Below are a few pictures of the test set up and of the mainboard under test.
