Hi guys , a friend gave me some GU29 tubes , so i want to make a stereo amp with them.
I've a pair output transformers from "Geloso" amplifiers , designed for EL34 in Push Pull , can I use them for gu29 in push pull ? B+ at 400Vdc
What is the ideal Raa for GU29? 5k ?
Can you suggest a good sounding tested schematic? Audioromy ?
thanks for the link, if i were to build this amp, i would put 10 ohm resistor in series with each plate so i can check plate current balance....
Can I suggest you look at my DC7 Mk3 thread to see a way of biasing up a shared cathode output tube. Its self adjusting and stable if the input valve stays reasonably well matched.
Shoog
links please...
thanks...
This method can be very techy to set up in the first place - not for the faint hearted. I made a small adjustment to the output screens last night and got red plates on one of the PL84's.
Shoog
Shoog
i understand, if i were to do this, i will put a 1 ohm resistor at the cathode and 10 ohm resistors at each plate, so that i am able to monitor total tube current and balance plate currents..
Here's my FU-29 based on the AudioRomy FU-29.
It has a better PS, different input tube and better operating points of the tubes.
thanks, i will regulate the screens to something like 180 volts, a mosfet type regulator or a maida will work here....i will likewise regulate the G1 bias supply...
I recently finished a PPP gu-29 amp. I built 'maida' style regulators for the bias and screen supplies.
It sounds very good!
200v on the screens,
610v B+
about -28v on the bias supply.
awesome, can you post pics please....
"Finished" was perhaps too strong a word. It's electronically done, but I am currently drilling holes in the panel. I used Pete Millettt's mono PP driver boards, so he takes the credit for most of the design.
The last pic I took of it is posted in his pcb thread. Maybe I can link to that pic...
Well, I can link to either the thumbnail or the large image.. If you want to see the larger version, it's here:
http://www.diyaudio.com/forums/tubes-valves/203110-mono-push-pull-driver-pcb-20.html#post3324923
Few questions , screens need a regulated voltage around 200V because of the absolute maximum rating stated in the datasheet right?
My supply would give around 400-450V , really I need a B+ of 600V ? Is just power output related or will work bad at 450V ? Never experienced with this kind of tubes
Anyway how much power do I get with theese tubes ?
Screens, yes, pay attention to the max voltage on the datasheet. They don't NEED to be regulated, but a lot of people think it's a good thing to do. If you don't regulate them, give them plenty of headroom for fluctuations in mains voltage.
Plenty of ppl build them w/ the lower voltage supplies. You'd be more in class A. Less total power, maybe less distortion. I'm getting well in to class B territory w/ my loadline.
Power, I'm not sure. At that voltage, look at what people w/ the AudioRomy are getting. (I'm guessing 25ish watts, so maybe 50ish watts if you're going parallel push pull)
I should be getting 80 or more watts out of mine (but have not tested it).
Edit, I should add, If you do regulate the screens, you've gotta regulate the bias supply too.
- Tubes / Valves
- GU29 PP Amplifier
