...or even better NIPPON CHEMI-CON Series PXA (~ EUR 1 each)
may I suggest NIC NRSG, 1000uf/35V
one at each mosfet
I will take 2 stereo pairs (4 boards).
Will you do a regulated supply board too? I'd take 8 or more of those.
Rush
Yes, I could. Please send a PM for more information.
I would like a pair of boards also, Per - can easily trim them down to 3 o/p Fets if required -
Could you add 2 small electro/solid poly caps across the rails to a separate 0Volt point near the jfet input, maybe 47uF+ ...
Jameshillj,
I saw you recommended that tweak in the F5 thread and wasn't sure exactly how you implemented it. I was also wondering if you can tell if your resistor upgrades can be used on these boards.
Thanks,
David
One more set for me pls.
Total: 2 sets
please note, this is not a GB/order thread
it is only to see if there is enough interest
and it looks like it
Hi all,
Thanks for your interest in the Juma F5 boards. I will definitely order a small run.
The boards will be FR4 1.55mm thick, two layers, 105µ copper cladding, green solder masks on both sides, white silk screen print on the top side. The production time will be approximately two weeks.
The price per set will be ~ EUR 25 (minimum 15 sets) or ~ EUR 20 (minimum 25 sets) plus shipment from Germany: EUR 3.45 Priority mail (max weight = 500g) + EUR 2.05 registered mail (optional) + EUR 3.55 insurance (optional).
Please email your authoritative orders by PM and let me know your shipping address and your email address. I'll collect orders till the end of the next week at least and will inform you about the effective price per set depending on the total ordered number then.
I will also offer regulated supply boards with adjustable output voltages on request. These boards do not include rectifiers and load/buffer capacitors. Please send PM for more information.
Here is a picture of the actual amp board. I added Papa's "tone control", a 200R trim pot paralleled to the 10R Source Rs of the JFETs (optional). The MOSFET degeneration Rs are MPC70 .33/2W.
Georg
[QUOTE=permaneder;3376150
One set (2 boards = dual Mono) will cost ~ EUR 20 (minimum order = 15 sets)
I will also offer regulated supply boards with adjustable output voltages...
wonder if this means I can finally find a purpos for my old 2kw monster trafos
they put out 2x 38Vac
would your regs handle this...safely ?
I have thought about making a 'one for all' power supply
not all amps, ofcourse
extern power supply only for various Pass Diy amps
when big enough it might even power several different power amps together
each amp would ofcourse still have their own lytic power bank
but connections etc are tricky, so i still have doubts
when in doubt , use proper sized hammer
whatever you do , golden rule is - max 50W per mosfet case
if you can cool it
same for reg
edit : when you calc size of heatsinks needed to make universal supply from your xformer - then it's cheaper to buy deedicated xformer for each project
if you can cool it
same for reg
They will. It might be necessary yet to double the MODFETs depending on the wanted current flow.
What regulated voltages do you require? It wouldn't be wise to feed the regulators with rectified ~ 55V and regulate them down to 20V...24V though. Too much needless heat dissipation.
permaneder;3376150 I will also offer regulated supply boards with adjustable output voltages on request. These boards do not include rectifiers and load/buffer capacitors. Please send PM for more information. One set (2 boards = dual Mono) will cost ~ EUR 20 (minimum order = 15 sets)[/QUOTE said:You are using a different regulator than Juma's, see below.
What is the advantage of your regulator over Juma's?
Rush
Rush
Juma's is cap multiplier
s.
One set = two boards = one stereo amp
no, I think its more like a filter
and works like a big cap, just more effective, in some ways
hence the name cap multiplier
I think its also less prone to malfunction
if you dont need a precise fixed voltage it might be better than a reg
you may still need to know how to calculate the correct voltage drop
but what do I know, I only assemble, cross my fingers, and hope it works
- F5 with 2SK2013/2SJ313
