your hearing is far too sensitive
You should educate yourself on Supreme Audio
Look around and find some 100W transformer, center tapped
destroy some chips before you get the right way
then you should educate yourself on Supreme Audio
Maybe your ears don't like chip encapsulated solid state,
maybe you'll like discrete transistors
But if you educate yourself on Supreme Audio
Maybe youll find that tube amplifiers and old vinyls are the only ones
that bring you satisfaction
Happens ...
Happens ...
Im no audiophile, my tda2003 usb powered sounds fine,but that just distorts so much even at less than 1wyour hearing is far too sensitive
Happens ...
Btw i have some vinils from my mom but i cant use them,i mostly listen to dubstep(dont hate me!),and some oldies
So i got a phone chrarger and i hooked it up to my once powerful tda 8560 and made it into a small amp for my laptop so my tda2003 can be sent to the tv which also needs some good audio,the charger is 9v 800ma and i did 15000uf cap to reduce voltage sag,which is still a big deal,i got some leds hooked up to it to light my room up and the dim with the bass
Adios hiss from tda2003,hello 50hz hum from transformer psu
If you followed what I said in my first reply
Hum from a *normal* trafo ?
You should rotate and move in space or the trafo or the circuit ( that may caption some noise by some groovy intercapacitance intersections-and resistive-the paths to ground ) to keep sensible parts away from some flux dispersion....force ?
Normall trafo but too weak far away from electonics.As its an wall wart
Maybe some diodes in the bridge rectifier died from overtemperature from when i salvaged it from the old board,the bridge wasnt new
Not for long ive been using stereo speakers,i really love the stereo efect,but my tda2003 i mono ,th sound system on my old comp has an burned chanell,and my tda 8560 had a sub on one chanel and satelites on the other now its all stereo ,havent heard any stereo sounf for at least 5 years,and the stereo image on my speaakers i grea
Btw have you even seen a cd that has that shiny part very red,when i was 5 i was taking apart a pc(at thaat time i was finding a lot of dumped computers but my mom kept thowing them out)and i didnt know a thing about computers.Took a computer cd drive apart and found a red cd inside,the shiny bottom was red not silve,and it looked awesome,I wold like some now
Anyone knows a good chip that runs at 12v to 5v,is powerfull and single chanell
Not too much output power with such low supply voltage, but I guess you can try the TD2822 in BTL mode.Anyone knows a good chip that runs at 12v to 5v,is powerfull and single chanell
Fine then just at 12 v but like 20w or so
Well... you can try a TDA2005 en BTL mode for just one channel (be careful, there are plenty of such chips badly fake). The chip is a bit sensitive to GND layout and decoupling, but there a lot of good PCBs in the market...Fine then just at 12 v but like 20w or so
i think il stay with the tda 8560q, but i want something like 4x50w that cn be bridged in 2x50w +100wWell... you can try a TDA2005 en BTL mode for just one channel (be careful, there are plenty of such chips badly fake). The chip is a bit sensitive to GND layout and decoupling, but there a lot of good PCBs in the market...
- Chip Amps
- lm1875 fizzing away probelm
