What is "no compromise"? I just look for posts that are well made and where it's easy to get a good connection. Cardas, WBT, Dayton Audio, whatever. It's the mechanics of the connection that concern me most.if would suggest me no compromise binding posts
simply transparent to signal path.
Bear, I don't think you are reading SY's posts very well, or you're reading something into them that I don't see.
SY said that it was imagination to find any difference between brands - in response to a post that asked that.
I'd say there are differences in some cases.
It's a crap shoot to a great extent.
Most are essentially "blameless" - some seem to have odd effects. So percentage-wise almost any will be ok.
However the implication, of SY's statements in this thread is that all of the metals used for audio connectors and wires sound the same. I can not agree with that at all. They simply do not all sound the same.
In most cases the differences are more subtle than the sound you might be able to detect listening to a car stereo or from a decent hi-fi set up. But in a very well set up and clean system, I find that there is no ambiguity at all in the effects of things like Rhodium and Copper and Silver. Of course if you use various things in various places, you spread the effects around and homogenize it all. Maybe that is not a bad way to go...
...in fact I find it down right disconcerting to hear this happen at all. Things would be much simpler and easier if it *did not happen*! It's confounding.
Are there more significant and important things to get right in a system first? You bet. Work on that first. Worry about metals and connectors later...
Why don't you share with us what your system consists of, or what you are building/modifying that will use these binding posts?
Fact of the matter is that everything in audio is a compromise.
Imo, one will need a "world class" tweeter, hearing to match, and almost perfect signal path start to finish before one need be concerned about what are extremely subtle factors like which binding post to use.
Chances are it will make no difference.
You are worrying about the wrong things. See Bear's post above.
SY, where is your tag line from?
They're changed from time to time. This one is from a rather controversial fellow named John Derbyshire.
Eddy currents?
Three things matter here:
1. Connection quality.
2. Connection quality.
3. Connection quality.
Why is that so difficult to understand?
If limiting to three, defining "quality" is helpful:
1. Initial electrical resistance of the connection, ideally being as close to zero ohms impedance as possible.
2. Resistance of the mating surfaces to corrosion, which can eventually increase impedance to infinity or create an impedance curve that affects frequency and dynamic range variations.
3. Resistance of the mating surfaces to physical deformation, deformation can also increase electrical impedance to a point of audible detection.
Point # 3 is often a problem for DIY types who tend to use the connections often, while #2 is the greater problem for static situations, especially in salt air environments.
The problem with #1 is "connection quality" is almost always good for most connectors initially, it's what happens down the road that separates the wheat from the chaff.
One comment on the "Dynaco" type screw terminals mentioned a few pages back. I now work for a company that does a lot of professional installations. These are for audio, video, and contact closure/power supply to external effects. Reliability is crucial and most of the connections are screw connections of some kind. the Old Dynaco/McIntosh etc. barrier strips are still used. However it is crucial to use them with matching spade connectors. Bare or stranded wires were an invitation to shorts and every amplifier manual in the 50s/60s had pretty diagrams about the evils of wires touching.
The only problem is that the wires then get crimped into spade connectors and the reliability problem migrates upstream (personally I would solder them into the spade connector. Too often a wire can be yanked out of a crimped spade connector). Still, the industry considers this a reliable connection.
The other half of our gear uses wires screwed into Phoenix connectors of various types. This is seldom bare wires, more frequently it is with crimped on pins that are screwed into the terminals. This gives a cleaner installation and less chance of shorting between wires.
David S.
David S.
Crimping is ok. I use Cembre crimps at work, and they arent half bad. However, the addition of soldering is almost necessary in circumstances. Pros dont bother, probably because given 5 years in a damp or salty atmosphere they degrade and need replacing. The only crimps Id consider a cold weld are the hydraulically applied types which are from 70 sqmm upwards. In those sizes the wire will break before it can slip. Speakon and XLR are great, until the contacts get dirty, and require regular cleaning. Not a problem with multi kW pro sound, but more of an issue with HE speakers and flea watt amps id suspect. Most are rated at 5mOhm contact R, clean bare wire or crimps, and binding posts are significantly better. I use binding posts for a resistance bridge measuring 20mOhms range. Joint R is a fraction of an mOhm. My 2 pence.
Eddy currents?
yeah I know, I usually dig them, but this one stood out and I wanted to know. thanks for the tip i'll look him up.
ive gone in a different direction with the current build.
i'm using Lemos for signal, 4 way speakons and ITT 8 way Cannon Bayonette MIL on the next multiway rear panel. easy, very secure and with hermetically sealed solder and mating connections. anything else gets pretty stoopid on multiway, multi-amped speakers and amps. i'll double up on the bass so 2 x 16awg pins per phase, then 1 each phase for the mids and highs
hard silver plate, but I dont expect them to degrade to quickly with no oxygen. the model # on the panel mount is CA3102E20-7P-B
I do solder if not crimped with the correct tool, when doing FAA harness's crimping is what is allowed, you need the right tool and connector, when crimped correctly much better than any solder joint ..
No heat also means no compromise to the insulator ....
http://aeroelectric.com/articles/terminal.pdf
I know not this FAA of which you speak (Slarty Bartfast), but in my experience crimping is used in panel wiring for speed more than anything, also spring terminals are generally used this side of the pond, and they Have to use bare wire, crimps are very unreliable in those terminals. Screw types which the US still use in the main are frowned upon since they rattle loose.
- Design & Build
- Parts
- Binding posts Brass vs Copper : does really makes differences ?
