I've measured the 3.3V and found very high level noise. Followed your Mod and added two capacitors at the input of the LDOs. Noise reduced significantly and SQ also improved. But the FF still not work
Good to hear about the caps. But sorry to hear that the FF is still not working. Have you measured the clocks without the FF connected? There is no way the clocks have such low voltage if VDD is 3.3v
The clocks are the same with and without FF
Did you fix you s/pdif problem?
Thanks Ian
Still have no time to check the signals, will try tonight and inform you the result.
Checked the SPDIF with scope and all I2S outputs have signal with either USB through backdoor or optical. The frequency is much higher when input from backdoor. No data output from FIFO when switched to optical.
Attached are the SCLK signals at SPDIF output.
Please show me waveform of all three SCK and WS and SD signals form S/PDIF board I2S output port when you switch to optical input.
Ian
Does anyone know if the pre made 50ohm coaxial cables like the ones Ian supplies can be purchased from anywhere else?
As I am not in your GB Ian I have assumed they are not available from you.
Try digikey, mouser, newark, avnet..... u.fl or ipx or ipex
Ian
have you tried searching u.fl ? they are everywhere
Yes
I obviously searched the wrong thing previously, I assume this is what I need http://au.mouser.com/ProductDetail/Hirose-Connector/UFL-2LP-066J1-A-100/?qs=sGAEpiMZZMtpPEYroCHctth6Gq0pfeUoDnsPvB9A7iY%3d
My original search came up with nothing that was in stock
you couldnt have
at digikey a search for u.fl returns 229 results for cable assemblies, which I narrowed down to 24 results for suitable cables from 25-100mm long. I like the 0.81mm black cable, because it looks nicer hehe
at mouser there is a similar number, but they are more expensive. then of course there are the other compatible trade names that Ian has mentioned above.
did you perhaps not include the full stop? did you search for ufl instead of u.fl ?
you couldnt have
I don't remember exactly (late last night) but I probably made the search criteria too long & included "coaxial" 50 ohms etc
I only searched at Mouser
thanks
- Digital Line Level
- Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV
