I suspect that my new tube amp (on the way) will like these cables, too.
What will it say if it doesn't like them?
jeff
jeff
I don't know, but it'll be in a whiny tone.
I do plan to try it with both sets of cables, to see if things play out the same as with my SS amp.
Heeeeeelp meeeeeee!
jeff
its the thin insulation and close proximity of conductors, and solid core, that concern me.
The best dialectric for wire would be air (or a vacuum), thin is good in that respect. Given typical voltage levels the insulation is adequate. The thin, soldi core high purity wire is why you use it.
dave
2 x 24ga copper conductors = 0.3ohms resistance one-way over 3.5m
Gladly. Shall we let this wretched thread about wire return to the obscurity in which it was deservedly languishing for over two years? Not only is it satisfying, you'll find it to be theraputic.
Heeeeeelp meeeeeee!
The standard formulas for CAT5 is either a single 2-wire pair or all 8 wires, solids to +ve and stripes to -ve. This provides reasonably low capacitance and inductance and resistance low enough to be tolerable with low-power systems. The various braiding formulas cause capacitance to go out of site and can cause problems with conditionally stable amps.
The lifting of veils thing smacks of placebo effect. Assuming that your original cables don't have wildly strange LCR characteristics, there should be very little difference in sound between those and your new CAT5 cables.
Bob
Bob
ive used 5 amp lamp cord with no issue on short runs. Dunno what AWG that would be, but for 12ft id think it would be ok, just. The gauge of cat5 isnt the issue to me, its the thin insulation and close proximity of conductors, and solid core, that concern me.
The twists in the cable rule out cross-talk in digital signalling, so I can only extraploate that they would do the same with analog interference (as cross-talk is due to analog EMI of neighbouring wires.)
Bob
Placebo, perhaps...
But how is it that I needed to adjust EQ after swapping cables?
Maybe I have actually lost enough in the bass that it sounds brighter, but I don't feel a lack of bass.
Some may wish to ignore the thread. I get that. However, I am not quite done exploring it...
Oh dear.
OK. Here's one possible reason. I'm not saying it is the reason, it is just an example. When shifting to very thin wire, it's not uncommon for people to say they have found an apparent improvement in the midband & HF. One cause of this are conductors that are too thin to handle LF current demands, and thus their dynamic peaks are more or less subtlely compressed while the higher frequencies are of course left relatively unaffected, thus subjectively emphasising them over the lower registers and making them sound clearer.
It could also be that there are some grains of thruth in Hawksford's paper. Some of the math and assumptions have been called into question, but Malcolm stands behind the work.
http://www.essex.ac.uk/csee/research/audio_lab/malcolmspubdocs/G31 Essex echo 1995.pdf
from here (lots of good reading)
Malcolm Hawksford - Publications
dave
dave
Oh dear.
Which is what I meant when I said "Maybe I have actually lost enough in the bass that it sounds brighter".
I changed from 16Ga zip cord to a singe pair of stranded wires from a Cat5 cable and sounded better on my MA 12p pencils. I didn't swap them back and forth with different music but added resistance argument makes sense to me so I will leave them there for now. I didn't raise them off the floor on plastic chairs so I will leave that tweak for another day;-)
What Scott says. Speakers with exaggerated treble are often reported as more detailed, when they are just balanced shifted towards the high end. Perhaps your power requirements really do require a thicker wire. This all assumes normal music that has a generally pink noise power distribution. It does not apply to current super compressed rock that is nearly white noise.
Bob
Bob
Solid core is the part I take exception to most of all. Buzzes rattles and wire breaks. The rest is livable. If i had cat5 just lying about then id use it. IThe best dialectric for wire would be air (or a vacuum), thin is good in that respect. Given typical voltage levels the insulation is adequate. The thin, soldi core high purity wire is why you use it.
dave
dont though, so buying some isnt any more value than zipcord.
@Scott: shame on you. Having an opinion doesnt entitle you to y
treat others' ideas like dirt. this was a thread started in good faith, to seek opinion, not incite bullish behavior. So much for the DIYA spirit.
apologies. Got the post totally out of context. Again. I think im guna be quiet until ive considered what im going to write in future. Again, humblest apologies.
- Full Range
- why use CAT5 cable?
