A couple of new pictures.
Measuring with BK2012 is very fast - faster than ARTA. Just two buttons when delay is set. When done save as ASCII (by using autosequence). Polars are stored in 36 curves as Z-Axis. Excel 2007 must be used because older does not accept more than 256 columns
Below is resulting data for those who willing to try make a crossover: Mummy equipped with BC DE500 and 12B100R. Angles: 0,5,10,15,20,30,40,50,60,80,100,120,150,180.
No with 7deg (14deg full) Should I set to 0 deg? Then it is difficult adopt both 1.4 and 1.5 inchers )
Yes, I am almost certain that the throat angle is almost zero degrees on the 951Pb but it would be great if someone could confirm the exact number. I think also the inner diameter is marginally greater that the outer.
This is great! So when can we order?
I don't have it confirmed by Radian or having a sectional drawing of the driver, but I tried to measure it without dismantling the bug screen. According to Guido Behringer the phase plug exit is Ø1.5". I measured 17mm from the exit to the phase plug. This implies a negative half angle of some 4deg.Yes, I am almost certain that the throat angle is almost zero degrees on the 951Pb but it would be great if someone could confirm the exact number. I think also the inner diameter is marginally greater that the outer.
Please don't blame me 0deg should be close enough?Negative angle is worst thing because demoulding requires positive angle.
- Group Buys
- Waveguides and horns
