Hi ALL
My new classs d with limitter is ready (Rev. 3.1)
regards
MANOJ
Hi Manoj:
Have you finished the design? are you going to share that?
Thanks for your support so far.
Raj
D
Deleted member 148505
thanks to jlester87
hi
very good work and good idea
every things just in one board
pic for pcb please
what about filter ?
My new layout for 1KW Class D with onboard OCP and onboard bias supply.
2 Pairs IRFB4227 TO-220
hi
pic for pcb please
what about filter ?
Hi Jlester,
OC only for -Ve path and no DC protect
MANOJ
HiHello friends I send as a pdf or triell do rar 3200 d pcb
i can not underestanding you friend
Hi Hadi,
EQ for my AUD600 AMP tested, very good quality for class d amp.
MANOJ
What is EQ Manoj?
What is EQ Manoj?
Hi Raj,
it is a frequency equalizer(audio band) for class d amp
regards
manoj
sorry
it was NUJ7307 maybe
Why this used? Advantage? Only one channel!
Hi Raj,
regards
manoj
Hi Manoj: Is this like equalizer? But this schematic shows one channel only. What is the advantage of this board?
And I have sent a PM, if possible please reply
Hi Raj,
yes it is a equalizer, wired a second order butter worth for HF,MF and LF all together tied to one out. it is for one channel only.connecting EQ with AUD600 the quality of the sound will be increased.
MANOJ
Hi Raj,
MANOJ
Wow great! I will try to make one if get that IC locally.
Have you managed see my PM?
Thanks again
Raj
Hi Friend
i can control that with micro controler and can control every chanell one by one.
it is beter for me in car amp
have nice time
this ic is stereo 11 band EQ.Why this used? Advantage? Only one channel!
have nice time
i can not find this ic in my towne
this ic is the fast op amp ic
Wow great! Can you post schematic? It would be really great to have a 11 band EQ! Really amazing
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
