6V6 line preamp
I had those on my #26 pre, before switching to transformer output with ll1660.
No doubt! :)
Let us know how LC load performs vs RC. I'm quite confident it will be better sounding.
I'm very intertested as I have a pair of Iso-Tango anode choke (TC-60-35W) 60H/35mA unused in my drawer that should fill the bill. With a Rdc of 730 ohms what I have to do to try them is to lower the supply voltage to 245-250 to get the same 230-235 V on anode as per the lastest sch.
Unless Salas will recommend some other mods..... ;)
diyAudio Chief Moderator
Joined 2002
It takes >=50K amp to do this FFT. The resistive one holds spec (worse) down to 20K, and the buffer down to 5K. Good luck when making it.
Salas, Could you explain further? Are you saying that this is sim'd performance of this amp with choke and resistor is better or worse. Have considered getting some chokes just to try. Just got new power transformer so will be rebulding it all.
yeap, single reg for 2 channels, takes the current like a champ ...
set to 63mA and 340V output ...
some day I'll try double SSHV2 to see -or better hear- the difference ...
*just visited a friend, I took from him a pair of kenrad 6V6 coke bottle and borrowed 2 tube testers (many 6v6 and 26 tubes to test) ....
its gonna be a funny weekend ...
Joined 2011
I am going to try with LC first. If I don' t like the result maybe try with RC, but I don' t think so.
Just a suggestion to avoid confusion. L is induction, R is resistance. LC and RC is low-pass circuits consisting an inductive resp. resistive load in series with a capacistance parallelled to ground, in audio concepts often used in filters, like smoothing B+ or i speaker filters to cut high frequences. Rp is tubes inner resistance, Ra is anode load. If La is a common term I dont know but it would make analogue sence? Or what shorts do you prefere guys? Bermuda? Just watched swede juniors loose the hockeyfinals against USA. Cheers!
Staffan
Joined 2002
Choke is better and it needs lighter amp load to maintain all the goodness in this instance. Not that it is a complete slouch at 20K output load, but see the difference to 50K that I had posted before in #1348.
Joined 2011
Buzz, Salas is speaking in tounges here as you notice. Every constructor will. That is becaus how your eventual preamp will work is 100 % dependent of your load, ie the poweramp or whatever.
Sum shorts: By every anode loaded preamp you test it will sound completely, and I mean compleatly different, against your load, ie the power amp.
Some anode loaded preamps will just fail, or go out of band if you load it to heavily.
The safest preamps (the best imo) doesnt care about the load. That is cathode followers or XXX:x anode loaded OPT preamps.
To many times I have heard people say "This is my preamp" and when they come home it sux.
CFs is hard to construct, very demanding and OPTs are expensive thats why.
Salas products are the best, no kidding, the very best. But you have to take the context in abbreviation.
Staffan
Joined 2011
