Current conveyor as a voltage amplifier
Disabled Account
Joined 2006
It is supposed to improve PSRR. Edmund uses a similar technique in his Super TIS. It conserves the rail-modulated currents through the 150k resistors, and combines them so they cancel. I seem to recall that in the original configuration, asymmetric rail variations would cause higher PSRR than normal. Forcing the 150k resistor current to flow through both loops caused asymmetric PSRR to improve. But I also seem to recall there were some innocent gaffes made on that part of the circuit that got corrected later.
Edmond abandoned the scheme later on and I see the reason why.
Disabled Account
Joined 2006
THD offcourse, just as I predicted, see page 4 of his thread, he found another way of increasing PSRR though, see his latest schematic on his website. His search though was for better PSRR and found better THD instead by rather using classical super pair arrangement. I must see how well this other scheme works.
I simulated with different values of the resistor connected between Q9 and Q10 emitters and there is no significant change in THD or PSRR, so I stick with circuit as it was with Baxandall super pairs. I have Dimitry Danyuk enhaced cascode, but I think it could not be implemented here.
dado
Disabled Account
Joined 2006
dado
In your case might be insignificant althouh Im betting on that with resistor between the two emitters there is a definite drop in THD however small. In my case with a power amp where a high power outputstage must be driven the THD is nearly 25 % worse off for the crosscoupling. Even Edmond had a useful reduction in THD. The action that makes a super pair so linear is somewhat negated by the action of the cross coupling. Classical Baxandall super pairs dont use cross coupling. When I have some time Ill look at the scheme later adopted by Edmond.
I simulated only current conveyor part, without output buffer, with cross connected resistors and resistor connected between emitters. I could get very insignificant drop of THD20k from 2.05 ppm to 2.02ppm but in that case the resistor was 4.7 kohm and dissipated 0.9 W(with 13 mA). One side effect was that power dissipation on Q6 and Q8 droped to 100 mW and low power transistor could be used. I am not sure if this is better.
dado
At R9 would be a (-) input port to use for cmr tests.
Thanks, I will do that.
Here are some photos of the GainWire boards.
Disabled Account
Joined 2012
CMR uses same source (1) to drive both inputs -- so use 2 series R from sig gen of maybe 1K or more going to + and - input ports. Looking for a difference plot. Should have >60dB rejection or cancellation between ports for optimum performance. SOTA would be >-100dB.
Maybe true for modular instrumentation amplifiers but this circuit will only be connected one way in one circuit. It has passed all the requirements so far so even if CMRR is low, there may be little to gain from increasing it with this particular implementation.
R7/R8 give the + input slightly extra gain. At a current gain of 18.54k at the Jfet sources, this calculates to a CMRR of 2.85db, which seems to agree with the simulation. R7/R8 need to be bootstrapped to the negative input or replaced with current sources.
I think in the first simulation since you bypassed the 1k resistor you caused major offset which saturated/clipped the output resulting in optimistic PSRR.
