NO NO
No, that's my dream SCH not a real thing but I think it should be 75% correct.
I don't have front end schematic because I'll try to put another front end on this topology, 14-20dB gain with SE tube but I need to invert output phase.
Regard
Anadigit
ANADIGIT
isn't back-engineering sort of low punch , considering that Nelson didn't published ,even partial , exact schm of M2 ?
Regard
Anadigit
well , I didn't made any sort of analysis what will happen if you include those TL431 there....
whatever - I have exact schmtc , but I didn't had idea to publish it and say - that's my dream schm
on the other hand - I deciphered NP's opto-bias and included it in my Babelfish J2 ; and that's exactly the reason why you can't find that schematic on-line .
I remove diamod buffer and auto former out off papa schematic.
Do it by yourself
You did not do it by yourself, very unfair to publish parts of the circuit here!
In this way the circuit sounds detailed but very thin. Not to recommend, normal F4 does the job better.
ANADIGIT
Regard
Anadigit
Anadigit, I have replied to your PM re J2 which I think you were up to the same thing with the M2 now. Buying an original to open it up and trace up the circuitry is indeed below the belt muai thai...returning it after from what I understand from your pm? It's not fair to Nelson but also the seller.
Please respect NP's IP and just be thankful for what he has shared thru the years.
No need to serious, my impress same as your though.
It's only diy job not a thing for knock under belt.
I like to learn from real unit and keep it in mind, take it easy
I know what you're doing. It's not about diy or learning. It's a serious cloning business!
No mods. Just copying everything inside out including the chassis.Mods?
- First Watt M2
