Destroyer x Amplifier...Dx amp...my amplifier
You know Epops, i have listened once again
And it is not that bad.... despite the camera is unable to capture the low frequencies, i can notice it is playing fine.
Maybe your computer monitoring system (audio amplifier and speakers) are not that good to reproduce bass...i could listen some...also you notice the door shakes, this means there are strong bass around...strong air pressure.
I am using the best Dx Blame i have and nice bookshelf speakers..they can reproduce 40 hertz without losses and can reproduce 25 hertz with some loss...i could listen some bass..not only the fart sound you said...maybe your speaker is doing that..check it and tell me something forward.
Well..sound is air in movement...if distorted or not is another problem, and there are guys that loves square wave sound (guitar players - heavy metal use distorters)...so...what is good for me may be bad for them and the opposite is true.
That deep bass test music, the traditional one that is played at the video's end, is really strange because it has very low frequency tones...when we use microphones to record, the result is the sound vanishes or is transformed in noises...if you try some recording you gonna notice that... electret condenser microphones use to produce noises when the diafragm hit it's end in compliance..and this happens with bass.
Some goodwill may change your evaluation and mood dear Epupa.
Have a schnapps man! .... and be happy..this reduces blood pressure and prevents heart diseases and troubles like cerebral vascular accidents.
Take care man...you seem to be to much serious...not good for long life forecast.
Carlos
A long time without feed the thread.... i am busy, travelling a little
And visiting my daughter...she has a new boy friend... a very dangerous one as you see in the picture...i hope she will not do that too.
I will produce a high power Dx Amplifier for my enjoyment... a monster.... to listen some "loosen" bass.
regards,
Carlos
Heheheheh... i am glad to know this.
Thank you Nico.:)
The one play with the puppy is my first daugther....she looks alike...but the young one, the teenager, is a little bit different.
Dx amplifier remains the same...old style, reliable and good.
Carlos
Thank you Ebbe.... i have lost 74 Kilos
But fighting to keep this loss...... my organism is trying to make me fat once more..... i could see 2 kilos up...and then a fight to reduce it....not so easy now a days to keep the weight as my body is recovered from the surgery.
Now i have less length of intestines.... my food absortion was reduced because of this lenght reduction...but this smaller intestines tubes is recovering and absorbing more and more.... this small portion is increasing it's efficiency.
From now on..if i do not care about...if i relax to be watching my weight and what i eat...then, for sure, i gonna recover a lot of pounds.... and to be a baby elephant once again is not impossible.
Daughters are really nice..thank you.
Thank you,
regards,
Carlos
I remember the DX Blame very well.
Layout: by Greg, my first DIY - project.
I remember its deep, black bass very well.
I have given my build to a friend, who uses them in a pair of active speakers: to drive the bass - of course.
Best regards - Rudi_Ratlos
Yes.... we both like the Dx standard...the Dx amplifier
I have some songs from you with beautifull bass...that plays good ONLY when listening to a Dx amplifier.
Herman, a Brazilian friend, is making an exercise...a research to make the pcboard better and better....well...this is a never ending job, because we will always find something that can be improved....for instance.... the spaces, or clearance, or room in between the small BD transistors.... these clearances are not well divided, not well shared.... two of them almost touches the big ones..when the center one has a lot of clearance.
I have sent him the suggestion....but in the reality, it is time to stop and "give a go" into it because this way we will never finish.
See his image... great job...he studied in an obsessive way, all details, rooms, spaces, clearances, positions and sizes...it is a very well made layout...of course he started from something and make it better...also if someone take this layout, can make it even better... a never ending job in the reality..... it is already a work of art..... an art work.
regards,
Carlos
  • Dx amp by Herman... version August 6th.pdf
Dx Dyno?.... from Dynosauro.. Dx tyrannosaurus?
... Dx Tyranno? ..... Maybe.
An old and good Dx amplifier... the old style design... loosen uncontrolled longer bass...less precise but beautiful in sonics.
Please... suggest a name for a huge power amplifier that may deliver more than a Kilowatt*
* = depending output impedance selected, power transformer VA rating, power supply rectifiers and filters, heatsink dimension and quantity of output transistors
regards,
Carlos
Ahahahah!...this reminds me a French , from Galia, that had trouble with the Roman
Empire.... the ancient Roman Empire.... names like Asterix, Vircingetorix, Dumnorix and other strange names
My friend Herman, that is not a German, he is an Italo-Brazilian (Italy) sent me an output....kidding of course, this is exageration.:)
This image gonna be fixed...there's an error in the zobel filter
regards,
Carlos
