And Now For Something REALLY BIG
My latest Altec build.
And the 4344 does look nice!!
It's a nice sounding system. It's 15" based set-up using a 2235. The larger 4345 uses an 18" 2245 with identicle upper componenets and crossover. A 4434 is not all that big compared to the 4345 which is about 10 cubic ft. Here a comparison shot to a JBL Array clone for size comparisons.
Rob:)
Administrator
Joined 2004
The Seas Prestige A26RE4 10" woofer makes a great midrange driver. Easy to cross, too.
Also in the same price range see the Seas Prestige FA22RCZ 8" fullrange. Superb driver. Either will mate well with a 15" or 18" driver.
You use the Altec 416, correct. Was this intentional, as it allowed dropping the midrange and mating directly to horns?
The 416 was typical in the A7/A5 speakers. And that's what I have. The 515 can also be used to good effect and is more efficient than the 416 with a reputation for better top end. Less bass, tho. Either can be crossed easily at 700Hz or higher. There are other choices, but this works, so I use it.
Hi all
I forgot about these. They might just be what you're looking for and will probably work well with 8w as they're a modern design that is designed to work with low power :
inConcert Miles
They might just what you're looking for, and they're a completed design. High efficiency (over 100dB/w), and not too big. And the drivers should be easily available in the EU. They also have a smaller brother:
inConcert Duke
Enjoy,
Deon
The A26RE4 looks very nice. Not sure about using a full ranger. Wouldn't a 'specialist' driver be better over the chosen range?
What are the T/S parameters & size issues to look for in a mid? eg. Some say 10inch is too big
As I've only had experience with FR drivers, what are the requirements for driver integration?
Very interested in the Beta8 though! What a turn up for the books!!! a budget mid being a cracker like that!!
Ex-Moderator R.I.P.
Joined 2005
Beta8 might be abit of a lucky strike from Eminence
and possibly Alpha 6C
might relate to that particular cone kit assembly
I would say thats the right size if you want optimal midrange quality
main advantage over a fullrange could be powerhandling
but if you never play loud...
Thanks again tinitus! you are a font of driver info :D
Thanks to you & others I've learnt more about T/S parameters and bass drivers in 2 days than I thought possible.
Can I ask? What are the T/S parameters & size issues to look for in a mid? eg. Some say 10inch is too big. Is 8 better and 6 better still? Why?
The inConcert Miles looks nice but if I'm not mistaken used a +£400 beyma tweet in each cabinet!!! to rich for my blood sadly :vampire:
True, it is not cheap, but worth every penny IMHO. Personally I think it is worth saving up for. What is the use you spend less money for far inferior results. Sometimes you gotta have patience and save up for the really good stuff. :)
Enjoy,
Deon
