Tanken 1808 (Tang Band 1808)
Pictures of Tanken1808 Image Heavy
Pictures...
More Pictures
More Pics
I am very happy with the sound. The drivers are getting easier and easier in the top end. I will need to look at a way to tame a little off the top, but the low end is great, better than my Fostex 225 Half Changs, and similar to my TB 1772 in the Half Chang. I will write more this weekend.
JP
W8-1808 (manuf. freq response)
You might be hearing the lift from 1.5khz to 3.5khz. I dare say most of us don't mind a little lift past 5khz. And at my low listening levels, it is required.
do you have any baffle step ?
Very nice looking speakers you have there !!!!!!!!!!!!!!!!!!
Norman
Norman, you are correct on the plot graph, but when you look at 1k through 20k, there is a significant 11 db rise, which needs to be taken care of. There are things in the works to do this, but now i'll have to settle for what it is. I currently have NO bsc circut in there. I was looking at a 1MH and 3 ohm R later on. Need to order those parts.
My gut says that you will need a bigger inductor than that. While deciding on the resistor value, you might substitute one leg of an L-pad.
Have you tried a zobel to tame the very top?
Bob
Seas suggest both a closed 60L box and a vented 70L box. TS parameters are quite dofferent from the Tangband so they need a different box. Quarterwave loaded cabinets should work as well. I had a look at the Seas driver today IRL and it is impressive. Much care has gone into the design. I might get a pair and put them in either backloaded horns or Decca quarter wave pipes.
