are the discrete op amp design crowd going to at least read Groner's op amp distortion paper, try to master the design details he has published for discrete op amps
SG-Acoustics · Samuel Groner · Discrete OpAmps
Today it is not needed. I would take one low noise dual opamp and combine it with one more single fast opamp that has better output stage, adding few resistors. The result will be one opamp that you can't beat by discrete designed opamp.
I certainly agree that many op amp parameters can be improved by using composite/multiloop monolithic designs; extreme low noise, hi V swing are the main limitations - limits that are only relevant for a very few home diy audio applications
And as remarked, he thought he was the first to conceive of the use of inductors in the emitters to limit gain at high frequencies, but it was, like so many things, prior art, which (like they do more times than not) the USPTO missed.
To be fair the schematics of the modules were not published until much later. In 1966 they would have been a trade secret, and if Dick invented it I have no idea why it was not patented at the time.
High voltage opamps for an output stage are available. It is not a problem. And an opamp made of several opamps will be still discrete. Or, I can make a hybrid IC containing couple of case-less chips, one with low noise dual opamp, another with high voltage opamp. It can even fit into existing DIP sockets.
Disabled Account
Joined 2012
Here is My challenge for a descrete opamp --> using any topology and transistor types (except expensive and/rare/obsolete/exotic types): no more than 8 transistors; drive 30 ohms or lower with no more than -105db harmonics, 20-20Khz; S/N ref 1v -unweighted to be at least -110db (input shorted). ; no use of dc servo, allowed - dc offset at output less than 2mV over time and normal use temp range. all when used at gain = 10 or less.
How much better than these requirments/specs can be made??
RNM
Disabled Account
Joined 2012
No, FET input and as simple as possible. I'd say it needs to outperform an OP627 on all audio specs.
EVUL's right it needs to use cheap readily available parts. The 2mV max offset is unrealistic with hand matched devices even most discrete duals are worse.
Trimmable to 2mv and stays there without servo.
Ok - 627 is goal. without dc servo in low gain app?? Cant require an IC added for dc servo in low gain apps. Should be required to Not use coupling caps anywhere -- too expensive and bulky.
HUGE thread! 27,000+ posts and this is Part2! :eek:
So, can I be bold enough to ask what exactly is this thread about? I assume it was to work out what was in John Curl's pre-amp?
Has this been figured out yet?
No doubt some smart-ar$e will suggest reading of the entire thread...:rolleyes:
Andy
For parts one and two together it's been 6 years, 7 months, 15 days:eek: As John says, go and read the first few 100 posts in part one.
Note, everyone, that what is useful is something both buildable and BETTER, even in theoretical approach. For example all balanced is better than single sided driver stage.
The design should be fast, low noise, and open loop LINEAR. Open loop bandwidth is debatable. Look at the topology of the AD797, for a good example.
diyAudio Member RIP
Joined 2005
Average would be zero? Far as I'm aware, the average of 10 VRMS is 8.99 V.
se
Yes; the a.c. average is 2/pi times the peak value, the a.c. rms value 2^(-1/2) times the peak value.
And, actually, most simulators have generators that require specifying the peak value.
Of course, in the absence of an offset, the average d.c. value over an integer number of cycles is zero.
