Loudspeaker Build Thread
Well, here you go, just fixed all parts with a few bolts to make the photograph.
Since some time both speakers are operational, that is: they play but no final passive x-over yet. I use the lyngdorf and Hypex to drive them for the moment. x-over at 350hz and 3,5Khz both 2nd order slopes. There is little to fault about this IMHO but still need to make some measurements to confirm this.
I first thought of running the speakers without a front/grille but I changed my mind and will build a pair of front (I included already some magnets into the baffle).
As a side note: After some burn-in time I let lyngdorf's Roomperfect do it's thing: the module says 20% correction needed whereas my previous speakers, Mirage M3si's, did have the correction percentages around the 60%. For good understanding: the percentage is the usage of Roomperfect correction capabilities/resources. As usual, at least in my case, the roomperfect mostly straightened some woofer-room interaction, secondly it improved the imaging.
